Can you remove water from the filter >
Old 12-02-2004 | 07:54 AM
David Haag
Default Can you remove water from the filter
If water gets into the fuel/h2o canister filter can it be removed by dumping it out and reusing or do you replace it. We recently had flooding here and I am worried water might have work its way into the fuel tank through the vent.
Old 12-02-2004 | 07:58 AM
mcollinstn's Avatar
Default Re: Can you remove water from the filter
Whilst removing known water from the tanks, you can indeed run and dump, run and dump, repeat...
Once you've got most of it out, you should then put a new separator on. The cellulose in the media gets water in it and it won't dump out.
mcollinstn is offline
Old 12-02-2004 | 08:08 AM
you can also install a racor filter on the same filter head with a metal bowl & a drain plug in the bottom. A little pricey but it is a great filter.
JIMG is offline
SkiDoc
9
02-24-2008 10:33 AM
twin242ls
05-25-2007 02:10 PM
Harper220
07-21-2005 05:37 AM
Formula Outlaw
01-11-2004 01:14 PM
