525EFI Winterization >
Old 12-15-2004 | 12:31 PM
masher44's Avatar
Default 525EFI Winterization
About to winterize here and what exactly do I not have to winterize the 525 with the closed cooling. I want to be able to do this myself and not have to get a new motor in the Spring
Thanks Jim
masher44 is offline
Old 12-15-2004 | 02:22 PM
Default Re: 525EFI Winterization
All you need to worry about, is getting the
water out of the inlet/sea pump, cooler circuit.
I have a 5 gallon bucket with a hose
coming out of the bottom.
Set the bucket on the swim platform.
I connect this hose to a flushing attachment,
dump anti freeze in the bucket, start the
engine, run it 'til the anti freeze comes out the
exhaust. ( you've displaced all the water in the
inlet circuit)
I spray fogging oil down the intake during this
proceedure also.
Takes about 5 minutes.
JaayTeee is offline
Old 12-15-2004 | 03:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
DO NOT SPRAY FOGGING OIL IN THE THROTTLE BODY!!
Read the manual.
You will gum up the air flow sensors. You can do this on a carb, not with EFI.
Proper procedure is upon your just prior to your final running of the engine, when you are pumping in your antifreeze...
...remove your Fuel/Water Seperator, dump out half the fuel, and fill the rest of the way with 2-Stoke (Mercury Outboard) Oil. There is lots of info here on OSO.
Sydwayz is offline
baja bailey
07-20-2008 07:24 PM
scottsumrall
Fountain
13
09-25-2007 09:36 AM
fatdaddy
22
09-08-2007 09:45 AM
gripit
8
12-22-2004 02:26 PM
bcoffield
6
10-10-2002 03:48 PM
