speed calculations >
speed calculations
speed calculations
Old 12-28-2004 | 03:15 PM
speed calculations
What kind of top end speed should be anticipated from a set of 30 inch bravo ones spinning 5300 in a formula 311 1988 no step. (1.5.1 out drives bravos )sHOULD i CHANGE GEAR RATIOS.? iS 1.5.1 HARD WITH A 30 INCH 4 BLADE ON AIR TIME / REENTRY ?
boatman747 is offline
Old 12-28-2004 | 03:21 PM
JCPERF's Avatar
Default Re: speed calculations
RPM divided by gear ratio times pitch times 5 divided by 5280 minus slip[10%]
JCPERF is offline
Old 12-28-2004 | 03:39 PM
Tantrum's Avatar
You must have some serious HP in those motors. With no slip factor your at 100mph. 10% slip would put you at 90.
Throttle control is the biggest factor in weather or not your going to tear up drives or not. With the kind of HP you must be pushing to spin the 30's @ 5300 on that boat I think drives are going to be an issue.
Tantrum is offline
Old 12-28-2004 | 03:52 PM
GPM
I always used RPM divided by gear ratio, times pitch, divided by 1056, I've seen as
much as 18 percent slippage, borrow a GPS, and be sure.
GPM is offline
Old 12-28-2004 | 04:05 PM
Sean H's Avatar
A to Z
5280/5=1056 same way to get there...
Sean H is offline
Old 12-28-2004 | 04:06 PM
Sean H's Avatar
A to Z
does hull style vary this greatly?
stepped? pad? cat? i would think they would vary greatly.... i haven't done much w/ speed formulas so i was just wondering..
Sean H is offline
Old 12-28-2004 | 04:24 PM
JCPERF's Avatar
Efficient stepped hulls say a fountain,skater are more likely to have less slip like 8 to 10%.The higher the x dimension the more slip.Usually guys will raise the propshaft height to get more speed.They will turn more RPM.The raise in RPM is due less drag which the boat will RPM because it is going faster.It will RPM more because the slip% is higher.
JCPERF is offline
Old 12-28-2004 | 05:12 PM
GLH's Avatar
GLH
I have 30" labbed turning on 1.5 Ratio drive at 5200 I run 81 mph. Straight V. 650 HP.
I have read that 30" is the most efficient pitch on a bravo outdrive.
GLH is offline
Old 12-28-2004 | 05:16 PM
JCPERF's Avatar
The 32 is supposively the most efficient according to Mercury.You need some stairs on that Cigarette.
JCPERF is offline
Old 12-28-2004 | 05:19 PM
I ANTICIPATE BETWEEN 80 AND 85 SOMEWHERE . Waiting on another warm day for a test ride !!!
PicChic
11-21-2007 10:46 AM
racer-x6
Prop Talk
3
04-12-2005 11:54 AM
TGOR
General Racing Discussion
3
03-29-2005 08:07 PM
blackhawk
08-27-2004 07:34 AM
FindMe
10
09-11-2002 06:34 PM
