Enderle Fuel injection >
Old 01-07-2005 | 11:08 PM
Comanche3Six's Avatar
Default Enderle Fuel injection
I have always liked the look of Enderle fuel injection sitting atop a supercharger. Is it feasable in a marine application?
Comanche3Six is offline
Old 01-07-2005 | 11:43 PM
mcollinstn's Avatar
Default Re: Enderle Fuel injection
You'd likely want to use the "bugcatcher" throttle body and an aftermarket ECU to drive the injectors electronically, instead of the old mechanical style.
Yes, It;s possible either way though.
mcollinstn is offline
Old 01-08-2005 | 07:41 AM
[QUOTE=sutphen30]have any pics of it.QUOTE]
This is the unit
Old 01-08-2005 | 07:42 AM
aTX427's Avatar
The owner of Hallet did his 40 with the bug catcher - it was in Hot Boat a while back. I always liked the way it looked.
aTX427 is offline
Old 01-08-2005 | 07:55 AM
GregP's Avatar
Talk to Blower Drive Service, they do the EFI conversion setups. - Greg
GregP is offline
Old 01-08-2005 | 10:07 AM
It looks great and performs great on cruise and top end but the bug or bird catcher has to be modified to work well off idle since these units were generally designed for drag racing and all out effort engines the off idle is berry violent what I do in the efi marine engines we've built with them is I close 1 and even 2 of the throttle blades off inside the part looks the same externally and the engines work much better in the off idle for good docking characteristics . Even with the throttle blades closed off they still flow around 1100-1400 cfm depending on the unit.Good luck Laz Mesa
MESABALANCING is offline
Old 01-08-2005 | 11:14 AM
blkhorse's Avatar
bds makes what your looking for(as in post #6)they come in 8 or 16 injector models.hard to tell that they are electronic
blkhorse is offline
Old 01-08-2005 | 02:18 PM
look here. www.blowerdriveservice.com www.hilborninjection.com www.koehlerinjection.com www.kinsler.com www.chiefengines.com. hope these links help.
JPD Motorsports is offline
Old 01-09-2005 | 04:19 PM
Thanks for the advice guys. I will call BDS this week and find out some detailed info.
Ed
Velocity Vector
Wanted
0
06-05-2008 09:41 AM
Noise Pollution
21
06-11-2007 10:09 AM
blownboat
12
02-08-2005 04:45 PM
Stingray69
2
08-17-2004 08:07 PM
meander77
1
05-14-2002 02:34 PM
