Cylinder head work?????????? >
Old 02-07-2002 | 06:48 PM
kaama82's Avatar
Question Cylinder head work??????????
Was wondering if anybody had any recommendations on a good but resonable cylinder head guy? Michigan/Ohio area. Thanks is advance....
kaama82 is offline
Old 02-07-2002 | 06:53 PM
JIMKID Motorsports's Avatar
Post
I think the guys name is fultz in detroit area does a lot of drge race stuff but does all other motor sports nice work
JIMKID Motorsports is offline
Old 02-07-2002 | 07:36 PM
Tinkerer's Avatar
Cool
VALAKO RACE HEADS
Tinkerer is offline
Old 02-08-2002 | 07:30 AM
Mbam's Avatar
Offshoreonly Advertiser
Post
The head guy (no pun intended) is Carl Foltz. His company is CFE. Not sure if he will do cast iron any more, as everything is CNC therse days. As far as I know, he does the heads for Sterling engines. You would have to check around to see how his pricing is, but I have found his work to be well worth it. If interested send me an Email and I will find his number for you.
Mbam is offline
Old 02-08-2002 | 07:59 AM
turbo2256
Post
BHPerformance 734 455 1905
Old 02-08-2002 | 08:32 AM
26scarab's Avatar
Post
Advanced Airflow Engineering (586)294-7915
Talk to Ron, he does the cylinder head and
camshaft development for Joey Griffin
(Pier 57) and also does some work for CFE.
CFE is also a good choice but like someone
else said , I don't think he is into iron heads anymore
26scarab is offline
Old 02-08-2002 | 09:41 AM
Shooter's Avatar
Charter Member #300
Post
Here's a question,
Is it more cost-effective to rebuild your heads and adding larger valves and such or just but a complete Dart or Merlin set?
Shooter is offline
Old 02-08-2002 | 10:05 AM
26scarab's Avatar
Post
It all depends on what your trying to do.
If your trying to add a little more HP to your existing combination , keep what you have and port it ,add bigger valves..etc. Providing you have something decent to begin with.
If your building a new combination or what to add major HP then it is better to start new or buy something that has already been ported.
I've got a set of iron oval port Merlins that were originally done by Sterling/CFE , I could never afford that , I ended up buying them used from Advanced Airflow, I also had
Ron due some more work to them and had an intake done. Sure they were a little more
than a out of the box Dart but I guarantee they work better.
26scarab is offline
Old 02-08-2002 | 01:18 PM
kaama82's Avatar
Talking
Hey guys thanks, but keep the opinions coming. I guess I should of said what my combination was to begin with. 496 MK 4, Canfield alum. heads 2.25 int 1.88 exh. 310 runners, 9.6 to 1 compression, Lightning stainless steel headers(dry) Hyd. roller, Brodix intake and 830 cfm (too small I think) Thanks...... Kaama82
kaama82 is offline
Old 02-08-2002 | 01:45 PM
dyno's Avatar
Charter Member #655
Post
Call Jim Valaaco heads he wins!!!!!mt .02
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
