TRS gimbal ring help needed... >
Old 02-06-2005 | 10:50 AM
Ted G's Avatar
Default TRS gimbal ring help needed...
84 TRS gimbal ring with u-bolt at top. Can the ring be removed without pulling the transom assembly??? What is needed to get the top pin out? Do you have to cut the housing like a Bravo???
Pics
Attached Thumbnails TRS gimbal ring help needed...-trs.jpg   TRS gimbal ring help needed...-trs2.jpg
www.cbpba.com
Ted G is offline
Old 02-06-2005 | 11:48 AM
Default Re: TRS gimbal ring help needed...
here is the housing shot , i belive you will have to pull the housing. those nuts will most likely fight you. the top pin nut is a biotch. you also have to remove the tiller arm , etc the ring is probably cracked where the u bolt seats.
Attached Thumbnails TRS gimbal ring help needed...-rx70001.jpg   TRS gimbal ring help needed...-rx70002.jpg
open87 is offline
Old 02-06-2005 | 11:58 AM
Scott B's Avatar
There is a gimble ring kit.. Comes with the new ring, plugs for the holes you have to drill, misc parts and a bellows....
Around 850 bucks..
I have the instructions for it at the office, could scan and email em to ya...
Scott B is offline
Old 02-06-2005 | 01:56 PM
Mbam's Avatar
Offshoreonly Advertiser
It's a pain, but it will come out. Same procedure as a Bravo, however the upper steering shaft is usually stuck in the ring. If you are not going to re-use the gimbal ring, cut it on both sides with a sawzall, and deal with the steering shaft in a press.
Mbam is offline
HotPursuit
Wanted
2
09-29-2008 07:54 PM
The Menace
Skater
12
03-21-2007 11:01 PM
Biggus
2
04-23-2002 10:28 AM
Biggus
04-22-2002 07:25 PM
