Numbers on outdrive >
Numbers on outdrive
Numbers on outdrive
Old 02-27-2005 | 05:03 PM
hpy540's Avatar
Default Numbers on outdrive
OF263167 can any one decier these for me?
hpy540 is offline
Old 02-27-2005 | 05:29 PM
Default Re: Numbers on outdrive
(of) Is The Year And I Think Its A 1995 Drive
z.zuperboat is offline
Old 02-27-2005 | 06:07 PM
Mbam's Avatar
Offshoreonly Advertiser
From Mercnet:
0F263167 5120136GS MERCRUISER BRAVO 1 1.36:1
03/11/1994 INVOICED
Mbam is offline
Old 02-28-2005 | 01:27 PM
hpy540's Avatar
Default Re: Numbers on out drive
Thanks and it was supposed to be a 1.5 to 1 drive. Where is the drive ratio rpm chart link? Also, is there any easy way to calc the ratio off the boat besides pulling the cap? I do believe the props i have will not be much good for this ratio. i have 1 4 blade 245 and 2 3 blade 25 and a 3 blade 27
hpy540 is offline
Old 02-28-2005 | 01:35 PM
hpy540's Avatar
I went to Bam and found the info i need for speed calcs. WOW.... 10% theoretical slip i should be able to kill myself rather easily....... 540 cid approx 675 hp and a 1.36 drive w/ 3400 lb boat and a 27 pitch..... even with the fudge factors it is over 100... In all reality i will be happy to break 90...
hpy540 is offline
team Tickfaw
5
03-09-2008 09:03 PM
underpressure
08-13-2007 03:22 PM
Apple a day
Fountain
34
06-13-2007 09:32 PM
Tom
06-19-2003 08:39 PM
