Turbine 101 >
Turbine 101
Turbine 101
Old 10-27-2007 | 05:31 PM
  #131
JIMKID Motorsports's Avatar
gerry thats cool is that a water brake they put on the out put shaft i used to build turbins neat motors i finnaly sold my boat the new 30 will be starting soon cant wait keep the pictures coming
JIMKID Motorsports is offline
Old 10-27-2007 | 05:50 PM
  #132
Originally Posted by KNOT-RIGHT
Check out this operation.
Looks great!
Old 10-28-2007 | 09:53 AM
  #133
Do the fuel control units have a pressure return line on these units?
Fast Algae is offline
Old 10-28-2007 | 12:32 PM
  #134
KNOT-RIGHT's Avatar
The fuel pumps on the boat have returns to tank.
The fuel control units provided by Mark-NYE also have
a return to keep the turbine fuel control from deadheading.
Here is a picture of the Mark-Nye unit.
This is also wired to the Safety laynard which kills
fuel in the event of ejection.
KNOT-RIGHT is offline
Old 10-28-2007 | 12:36 PM
  #135
KNOT-RIGHT's Avatar
Yes I beleave it is.
I noticed your going with the 480cube small blocks.
Pretty sweet Dude!
Old 10-28-2007 | 02:07 PM
  #136
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
no
Rik is offline
Old 10-28-2007 | 05:48 PM
  #137
J-Bonz's Avatar
Nice test cell, Great build up
J-Bonz is offline
Old 10-28-2007 | 06:23 PM
  #138
KNOT-RIGHT's Avatar
Here is the Block party for the fuel system.
The Mark-nye fuel shutoff I beleave will be placed at
where it says fuel solenoid valve.
I do not see any fuel returns in the Turbine fuel regulator.
There is however a fuel purge when shutting down the turbine. This is there because of the long periods that helicopters can sit...This will prevent the fuel from schalacing in the nozzles.
The bottom of my exhaust has a built in catch for this purge with a drain. It has nothing to do with the exhaust it is just
attached to it.
Old 10-28-2007 | 08:50 PM
  #139
FREEDOM US1's Avatar
Skater Brother
attached to it.
Good luck! Looks like your still having fun with your Skater!!
FREEDOM US1 is offline
Old 10-28-2007 | 09:09 PM
  #140
Typically, the fuel at shutdown has to do with "where to put it". On shut down, as pressure in the nozzels decreases, a shuttle valve cuts the fuel off to the nozzels, and since the fuel control has positive displacement pumps, that fuel (while the fuel control is still spinning, i.e., pumping) has to go somewhere until the gas generator has stopped. It gets collected in a can and gets recycled either by burning on the next start, collected and dumped, or whatever.
