Turbine 101 >
Turbine 101
Turbine 101
Old 01-18-2008 | 05:18 PM
  #321
KNOT-RIGHT's Avatar
Getting the drive shaft as straight as possible and honoring
the exhaust was alot of fun.
KNOT-RIGHT is offline
Old 01-18-2008 | 05:37 PM
  #322
L@@ks good Bro keep up the great job , put that Biotch inside the bldg and turn up the heat
Old 01-18-2008 | 07:47 PM
  #323
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
When are you going to get off your butt and fire the engines?
Charge the batteries, bleed the fuel system, luckily it's so cold you do not need any prisp, and fire that thing up.
Rik is offline
Old 01-19-2008 | 07:08 PM
  #324
DONZI's Avatar
The man is simply KNOT RIGHT !
[YOUTUBE]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/B6-BuvVj8AY&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/B6-BuvVj8AY&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/YOUTUBE]
DONZI is offline
Old 01-19-2008 | 07:15 PM
  #325
DONZI's Avatar
Shut down-
http://www.youtube.com/watch?v=TbsRvANRtzw
DONZI is offline
Old 01-19-2008 | 08:05 PM
  #326
The Menace's Avatar
That's what I've been talking about. Will you be able to sleep tonight?
The Menace is offline
Old 01-19-2008 | 08:45 PM
  #327
All I can say is awsome
satisfied1 is offline
Old 01-20-2008 | 07:56 AM
  #328
KNOT-RIGHT's Avatar
Donzi thank you for your help today.
I see your still camera has video mode.
The technology designed in these engines is amazing.
I am actualy on the phone with JIM at PPS (Turbine builder).
in the shutdown video. I can just about here him.
He walked me through the first ignition sequence.
It responded and did exactly what he said it would do.
I fired up the second one and it was a mirror response of the
first.
We were keeping a eye on the upper hatch corners they were
slightly in the exhaust stream.
(Halon1211 sitting on the transom)
My start sequence was.
Engage Spool up with igniters, Fuel solenoid, Start fuel all at once.
N1 is at 10%
Watching oil pressure (20-30psi),Pyrometer 0.
You hear a quick Woosh. (Flame)
N1 starts to climb 20-30-40%
pyrometer starts to climb 400-600. At 900 I release start fuel.
Then release spool.
Pyrometer stabalized about 800
Oil pressure at 90psi
N1 is at 46%
We are now at Ground Idle.
This all happend within 25 seconds.
I am so freakin excited...Its all I can think about!
Wind chill will be below zero today.
I think I will chill and watch the Pats.
Old 01-20-2008 | 08:56 AM
  #329
Sick Stinger's Avatar
Brotherhood #1
Gerry long time no talk. Yoyr beyound nuts you know that right? You + Turbines= watch the *&ck out Cant wait to see it. If you ever need anything just give me a ring.
-Mike
Sick Stinger is offline
Old 01-20-2008 | 04:05 PM
  #330
Nice Pair's Avatar
"Congradulations" Neat project, Great read, Keep up the good work.
Nice Pair is offline
