3M Fuel Cell Gel Coat >
Old 07-07-2008 | 04:44 PM
Originally Posted by dreamboater
freerider, are you having problems with your tanks? I have a 2000 28 and have yet to see problems.
do you run ethanol fuel?
RobF is offline
Old 07-08-2008 | 06:48 AM
dreamboater's Avatar
I have been running ethanol fuel for 2 seasons now. I dont leave a lot of fuel in the boat, I normally put enough gas just for the day.
dreamboater is offline
Old 07-09-2008 | 12:36 PM
Originally Posted by masher44
Going with aluminum. F that spray crap.
How did you adapt aluminum to the same space? Did you remove the "shlosh" baffles from the tank space?
Did you have a shop do the work and what kind of cost did you run into?
Thanks!
Don't Bite Me! is offline
Old 07-25-2008 | 10:26 PM
I haven't had problems but I called Skater and told them what year I had and was told I would need to have the tanks done. Maybe not right away because the northwest doesn't use a high blend of ethanol but as gas blends change I will need to. I don't want my tanks to melt or cause any engine damage.
freerider is offline
Old 07-29-2008 | 10:52 PM
I am working on a 40 classic and I dont see how you would get an alluminum tank down in the hole without cutting the deck out. I put bladders in freedom much easy'r
riggerjohn is offline
Old 07-30-2008 | 07:21 AM
Have'nt heard of any engine damage from melting tanks you should have fuel filters that will catch the fingernail size pieces .. but the gas leaking in the bilge and soaking into the balsa im told is'nt a real good thing
Good luck & take it to SKATER
Old 07-30-2008 | 10:26 AM
masher44's Avatar
Thanks!
turns out mine had no baffles in the cell I had to cut the floor out, cut the deck out, cut the cell out, grind out the left over purple crap, custom fab a new aluminum tank WITH baffles and all the trick stuff to the same space and put it all back together. Only lost 3 gallons of capacity. wasnt cheap but know I have peice of mind and dont have to worry about it ever again.
My boat is an Activator and a boat builer here did the job for me. cost was just under 5k.
masher44 is offline
Old 07-30-2008 | 03:02 PM
Brad Zastrow's Avatar
I acutally lost an engine on my 35 Motion a few years ago when gas switched to alcohol blend. I had a very large water seperator/filter that was plugged up with large resin gunky crap. Engine leaned out and let go. I had to change the filter three times a years after that. Motion uses the same method of in tank construction like Skaters.
Brad Zastrow is offline
Old 07-30-2008 | 04:06 PM
Brad So when gas switched to alcohol ?????? Our fuel filters were clogged every 30 mins but we spun them off and put fresh ones on watched the fuel pressures and never dropped below 8 pounds
Chris288
Detailing, Painting, & Fiberglass
7
09-20-2007 04:31 PM
Fenderjack
14
02-14-2007 07:22 PM
JJONES
6
10-12-2006 09:36 PM
pb
7
08-24-2005 01:19 AM
Pure Energy
02-21-2003 07:05 AM
