Outboard skater BS thread! >
Old 03-01-2017 | 08:22 AM
  #901
LAriverratt's Avatar
visited the factory only once when the 28 was there getting tanks repaired...Peter was out but we did get a tour. my 28 looked small in there.
LAriverratt is offline
Old 03-05-2017 | 06:23 PM
  #902
Nice Pair's Avatar
[ATTACH=CONFIG]565340[/ATTACH] :-)
Nice Pair is offline
Old 03-07-2017 | 05:22 PM
  #903
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
This one is in the paint booth
[ATTACH=CONFIG]565406[/ATTACH]
This one is next to get a deck
[ATTACH=CONFIG]565407[/ATTACH]
Attached Thumbnails Outboard skater BS thread!-img_6593.jpg   Outboard skater BS thread!-img_6594.jpg
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 03-07-2017 | 07:09 PM
  #904
I have heard there are several 28's on order and per Pete Boden's facebook at least one with 400r's.
Looks like Skater is going to join the 130mph club!
Double Rigged is offline
Old 03-08-2017 | 12:33 PM
  #905
Zero Patience's Avatar
Where is everyone at? I have been using mine. I installed the verado steering pump. Love it, one finger driving.
Lets play!
Zero Patience is offline
Old 03-08-2017 | 12:38 PM
  #906
Zero, How did you end up wiring it? Did you use the control module or dash switches like I did?
Taboma is offline
Old 03-08-2017 | 02:45 PM
  #907
I used dash switches, there were unused ones from the old 2.5 high pressure pumps. Supplied both from the ignition switch so i would no forget and leave them on. There is no load on the two switch wires. A great addition. The Merc way added to much weight. Watching the voltmeter when running itd never below 13.5-14 volts
Old 03-08-2017 | 07:00 PM
  #908
Good call!
Taboma is offline
Old 03-08-2017 | 07:12 PM
  #909
Nice Pair's Avatar
Lets play!
What does the Verado pump need for a helm?
Old 03-08-2017 | 08:03 PM
  #910
Remove the capilanno, install a Charlyn helm for two rams, you will need a steering stem also to mount the Charlyn to. I did not want to look for adapters to get from verado to jic hose fittings so I cut off the merc verado end on the pump shock hose and crimped a jic onto the merc hose. Then it's easy, use existing hoses to rear rams, add pressure hose from pump shock hose to Charlyn pressure port, add return line from helm to pump. It is self bleeding like the steering on my Cigarette. I blew out the old fluid with air pressure. I mounted the pump up front over the tunnel close to the helm. Ran #6 wire to port battery, connected control to two switches. Turned it on, full left to right turns to bleed it out. It works great if you remember to turn it on.
