Outboard skater BS thread! >
Old 04-24-2017 | 07:27 PM
  #971
I think its time to set up some gopros at 120 fps and run the boat.
Australia is offline
Old 04-24-2017 | 07:41 PM
  #972
This should suffice:
https://youtu.be/Zfx6l8q3lSw
AZMIDLYF is offline
Old 04-28-2017 | 05:53 PM
  #973
Nice Pair's Avatar
"I gotta new t-shirt" :-)
[ATTACH=CONFIG]566861[/ATTACH]
Nice Pair is offline
Old 04-28-2017 | 09:37 PM
  #974
Figured I post a picture of my just finished ride 15 inch 250 hp etecs 3.3 on 3.0 mercury sportmasters. Now to get rid of the purple and move batteries to the bow. [ATTACH=CONFIG]566872[/ATTACH][ATTACH=CONFIG]566873[/ATTACH]
Attached Thumbnails Outboard skater BS thread!-20170423_115407.jpg   Outboard skater BS thread!-20170423_115127.jpg
risco is offline
Old 04-29-2017 | 07:03 AM
  #975
Nice job how does it run? Weight in the bow is never a bad idea!
Double Rigged is offline
Old 04-29-2017 | 08:53 AM
  #976
Anyone have the water ramp diagram where to cut in for the 24 with etecs. Cannot find the one I had I was going to send him.
Esox4130 is offline
Old 04-30-2017 | 04:20 PM
  #977
Runs strong one motor is brand new rebuilt. So have to stay under 4000rpms for couple hrs but pulls hard with 1.62s and 30.
risco is offline
Old 04-30-2017 | 04:21 PM
  #978
I've been looking haven't found anything yet. Thanks for your help
risco is offline
Old 04-30-2017 | 09:31 PM
  #979
yeah I've seen that before. Do we know what hull that is on? I'm guessing each hull has its own airflow and vacuum characteristics at speed.
Old 04-30-2017 | 10:12 PM
  #980
All boats will be about the same - 1/4"-3/8" depth tapering to 0.00" @ approximately 8" forward of the transom. You won't want to go deeper than 1/4" - 3/8" into the glass at the transom, as you might start getting into the coring/transom wood. I recommend you coat whatever you modify with resin to assure a seal-coat over what lies beneath. I had to do this to my first 28 to get my water pressure back when I went to 2.25" above the bottom with the gearcases.
Skater30 is offline
