Outboard skater BS thread!
#981
All boats will be about the same - 1/4"-3/8" depth tapering to 0.00" @ approximately 8" forward of the transom. You won't want to go deeper than 1/4" - 3/8" into the glass at the transom, as you might start getting into the coring/transom wood. I recommend you coat whatever you modify with resin to assure a seal-coat over what lies beneath. I had to do this to my first 28 to get my water pressure back when I went to 2.25" above the bottom with the gearcases.
#984
Look same as my 21 with twins. After they were cut in it pegged the water pressure. In the 21 there is no core there it's just about 3/8-1/2 inch thick fiberglass with no core for the last foot. I assume the 24 is the same.
#985
Again thanks for all the help Ryan and also here a picture of my last ride [ATTACH=CONFIG]567267[/ATTACH]
#986
It's to feed the other water if it loses pressure when turning etc. when mine were cut in it pinned the water pressure gauges same with my buddy's 24. If your worried about getting into the core take the drain out to check but pretty sure it's going to be like my 21 and be all glass the last foot. Let us know how it goes.
#987
Thank you all going to try this weekend will let you know how it truns out . I'm maxed out on plates can't go down any more so this is my last option. Also another how do you guys feel about hooking both engines together with a hose in back seen it done before just didn't understand reasoning behind it.
#989
No valve in mine. I haven't had that problem. I guess the water pressure from the "lake" that the gear case is in creates enough resistance (pressure) for the water in the running motor to get to the impeller without dumping to the off motor, then the impeller does it's work. I have noticed an X-Cat with what looked like a ball valve to separate the motors, when desired, installed. A check valve would defeat the system IMO.
#990
Anyone know what product I can use to fix chips on my spray rails from loading on the trailer? All my research says to use Iron 555-U that is no longer available. Has anyone confirmed that axalta Imron is the same product just rebranded?
