skater 24 >
skater 24
skater 24
Old 10-14-2002 | 06:40 PM
big poppa pump's Avatar
Default skater 24
do you mean 4 inches below the sides?
still looking for a race hatch
do you know where you can get a windshield
my has a bend in it
big poppa pump is offline
Old 10-14-2002 | 10:19 PM
Ryan Beckley's Avatar
Racer
Racer
Lightbulb
4 or more inches down. I had my windscreen made out of Lexan at a plastic place.
Ryan Beckley is offline
Old 10-15-2002 | 10:47 PM
on the bottom of the hull it has water pickups witch were
connected to the adapter between the powerhead and
midsection , does any body know if it goes aal the way
through to the triangle piece (from the tubefrom the lower
unit)? i dont want to run the hose to the lower unit.
Old 10-16-2002 | 03:27 PM
Flyinbrian's Avatar
Triangle piece?
Those pickups are worth speed, could you post some pictures of them? I have a 24 Skater and would like to put a set on mine. From what I have seen, water pickups on the transon go directly to an adapter on the exhaust plate.
Having those pickups allow you to raise the motor higher.
Some guys even fill the low water pickups on their lower units, so it's completely smooth. Then when idling, they run an electric water pump to feed the motor.
Post this question on S&F if you get no action here.
Flyinbrian is offline
Old 10-16-2002 | 06:00 PM
hey flyinbrian
the waterpickup are on the bottom (underneath)made in the
hull . try to send you a picture of it , when i figure how to work
the damn camera.
Old 10-18-2002 | 11:10 AM
skatermike24's Avatar
If its a true 2.5 adapter plate the passage goes all the way through, I made my pick ups from stainless tubing, as far as the windshield goes, Ryan is right I made mine from Lexan, sprayed it black, looks good as new and won't pit anymore from salt water.
skatermike24 is offline
Old 10-20-2002 | 12:18 PM
skatergear's Avatar
Call the factory. We custom make windshields. Cost approx $500.
(Skater GM)
skatergear is offline
Alex17
Skater
4
12-08-2005 11:18 AM
apache21
03-18-2003 08:07 PM
JIMKID Motorsports
05-16-2002 11:17 PM
