Go Back  Offshoreonly.com > Owners Forum > Sonic
Sonic wiring >
Sonic wiring
Sonic wiring
Old 04-15-2007 | 04:44 PM
hp500efi's Avatar
Member #9
Default Sonic wiring
31SS, trying to figure out where Sonic runs their wires? Looks like they run it under the cockpit floor. I have shore power and I found where most of the wires are under the passenger dash panel but they disappear...thinking they go under the floor...
Is that the case or ??
Member of the Liquid Jungle
hp500efi is offline
Old 04-15-2007 | 06:11 PM
GO4BROKE's Avatar
Under a false floor in the side storage compartments. Just pull them up.
[img][/img]
GO4BROKE is offline
Old 04-16-2007 | 06:40 AM
hp500efi's Avatar
Member #9
Thanks, I will check that.
Where is the easiest place to grab a ground for the amps I am installing? I am installing them in the compartment above the fridge. I found a big ground block in the compartment under the passengers dash panel however I believe that ground panel is for the shore power.
hp500efi is offline
Old 04-16-2007 | 06:34 PM
GO4BROKE's Avatar
You can use that ground block for the stereo, but I would run a direct cable for the amps.
[img][/img]
GO4BROKE is offline
Old 04-16-2007 | 06:53 PM
GO4BROKE's Avatar
Sorry, I was interrupted. I would run 2 gauge cables (you can get cable and connectors from NAPA, use a propane torch to solder the connectors on) from 1 battery straight to your amps. They will have all the power they need and will minimize the effects a heavy draw will have on other circuits in the boat.
[img][/img]
GO4BROKE is offline
06zx10r
05-30-2007 01:33 PM
hp500efi
6
04-30-2007 10:47 PM
gofast000
Sonic
34
11-25-2006 07:01 PM
klmken
4
04-17-2002 09:50 PM
fandango
5
03-25-2002 10:13 PM
