Go Back  Offshoreonly.com > Owners Forum > Sonic
Question for fellow Sonic Boaters >
Old 05-13-2007 | 12:26 PM
Default Question for fellow Sonic Boaters
Hi,
Put the 358 in for the first time yesterday. We were very pleased to say the least!
Can anyone weigh in on why the port trim tab indicator stopped working but the trim tab itself is working????
This is an '02 358 w/ twin 500's.
TY
Mike
powerquest280 is offline
Old 05-13-2007 | 05:27 PM
I would think you must have a problem with your cable, more than likely at the tab end. Check the cable on that K-plane! Steve
509 SC is offline
Old 05-13-2007 | 07:15 PM
Thanks Steve,
How shouod I check this cable? The boat is now in the water. Do you know a lot about Sonics?
Mike
Old 05-14-2007 | 05:25 AM
East Coast B's Avatar
I'm currently working on the cables for the drives on my 31, however the tab cables are the same. Being that you are in the water will make this difficult, any way of pulling it out for a short period? If you disconnect both ends, you should be able to push and pull the cable by hand to see what might be causing the problem. Actually, just disconnect the cable at the trim tab and push pull the cable, should be only about 4" - 6" length you can pull in or out. If it's not working, either end would have to have come disconnected or the cable snapped inside the sheathing which would allow you to pull the cable all the way out. Once you have the one end off, you should find out right away what the problem is. Good luck!!!!
East Coast B is offline
kennyo
TN Powerboat Club
9
01-01-2008 12:21 PM
crsnang
Ft Myers Offshore
15
06-22-2007 10:18 AM
THRILLSEEKER
09-12-2003 07:35 AM
