Go Back  Offshoreonly.com > Owners Forum > Sonic
502 MPI vapor lock >
502 MPI vapor lock
502 MPI vapor lock
Old 04-11-2008 | 09:57 AM
txriverrat2001's Avatar
Does your model have the plastic covers around the fuel/water separator?? I know some do and some don't - and those that did, and were not reinstalled will vapor lock as well.
txriverrat2001 is offline
Old 04-12-2008 | 07:19 AM
go propless's Avatar
not a coil problem boat runs great, just shuts off while comming up on plane.
not sure where these plastic covers are that you are refering to? I don't think I have them I'd have to look?
go propless is offline
Old 04-12-2008 | 08:43 AM
I think he is refering to the plastic cover over the cool fuel device.
LordStanley74 is offline
Old 04-12-2008 | 01:44 PM
Wish I had those covers. I wouldn't be having these problems
Old 04-14-2008 | 08:41 AM
Default On the later models
they have the parts listed as #13, #14, and #15 in the pic.
Part numbers are : 807956T, 807806T, 807807T
Old 04-14-2008 | 03:37 PM
Thanks I will check on those covers mine dosen't have them.
Old 04-14-2008 | 03:39 PM
Some have them from the factory - some don't. All I know is they are there with the Cool Fuel system and if you don't put them back - they're known to vapor lock...
Old 04-14-2008 | 04:20 PM
c_deezy's Avatar
Sounds like you have already talked to the guy I was going to suggest, he is on one of the local boards and seems to have that same problem (with the Boss 302). I think he solved it by buying a Cig Top Gun
These has to be some common denominator tho, because if this problem was more prevalent then everybody with a 502 would be having similar problems...
c_deezy is offline
Inspector
103
06-27-2014 02:32 PM
rssteiny
22
08-25-2008 02:16 PM
cloudmaster_321
1
09-07-2006 07:20 PM
bj502
12
03-15-2004 08:12 PM
Diablo
Sonic
7
02-11-2002 04:57 PM
