Go Back  Offshoreonly.com > Owners Forum > Sonic
31ss that runs 80+???? >
Old 07-14-2010 | 08:21 PM
  #101
hunster's Avatar
500 efi's xr and herrings. 86 all day long
hunster is offline
Old 07-14-2010 | 09:04 PM
  #102
upstate31sonic's Avatar
Originally Posted by Jim Diesel
You running 28s?? 30's
What were you running before.Speed..RPM.. 80 5000 props were in bad shape
RPM now? 5300
How much fuel? 1/4-1/2
How many people?? 4
Weather conditions??? great
up river..down river..Lake??? down
Water conditions and temp???? 3' and 80
Wind conditions.head wind. tail wind???? not sure
Thanks for your honesty!! Now I do not feel so bad!!
Interesting that you are running 30's..My ride came with 28's from the factory and I tried to have them worked from that point..Maybe we should have tried some 30's
upstate31sonic is offline
Old 07-15-2010 | 07:45 AM
  #103
Dyno, I find it a little ironic that they are saying your numbers don't add up... I have a 1989 sonic 30.5ss... Been talking go bblades crew and they keep saying that my gear ratio-prop-slip ratios don't make sense. I have stock 454's 330s, 1.5 gear ratio on bravos and bravo 1 props. I gps at 62 mph running 4600 rpm. I don't know what to say other than my numbers are consistent. I am replacing both tachs this winter to make sure my rpms are reading correctly. I was also told that sonics are supposed to have a 1/8in hook in the bottom and it seems this thread is suggesting to get rid of that. My biggest complaint has been pourposing issues. Any trim at all begins to cause a porpoise in my boat and I almost wonder if it's under powered or underpropped not allowing enough stern lift or forward inertia to stay out of the porpoise. I would be interested to see what all you find out.
FuelinAround is offline
Old 07-15-2010 | 12:51 PM
  #104
Plum_Crazy's Avatar
Bruce at Sonic instructed me NOT to remove the 1/8" hook as it's designed in to stop porpoising. I think your problem would get worse.
Have you checked your drive toe? With your power and spinning outward, you should be running close to parallel or maybe toed-out \ / about 1/16".
Plum_Crazy is offline
Old 07-15-2010 | 04:36 PM
  #105
Not sure how to check my drive toe....
Old 07-15-2010 | 05:26 PM
  #106
U messure the front of the bullet ( propshaft tip ) center and the back of it , propshaft center !!!!!!
if both read 36 then u have +/- 0 toe, if the front messures 1/16 more u are 1/16 out if the front is 1/16 less u have 1/16 in !!!!!
Also , if u spin outward u should be toe in ( front messurement ) , my 30SS ( same boat ) had 1/8 out !!!
Hope this helps.
DareDevil is offline
Old 07-15-2010 | 06:19 PM
  #107
Plum_Crazy's Avatar
Measure between prop shaft centers and measure between the nose cone centers. They should be the same or, for toe out, the nose cones would be about 1/16 to 1/8" further apart.
Old 07-15-2010 | 10:58 PM
  #108
I will check tomorrow! Wasn't trying to jack the thread just wanted to start some informative old sonic discussion
Old 08-10-2023 | 10:44 PM
  #109
I'm removing my hook this week. It's 3/16" and its fairly consistent from strake to strake. Time to make about 3 pounds of dust. Porpoising only happens at lower speeds and if you want to go slow then simply run a little tab.... These boats don't porpoise above 60mph unless you've run the trim way too high way too soon... But that mean someone had jumped the gun and we all know that never happens.
im MartinB is offline
Old 08-10-2023 | 10:49 PM
  #110
I've noticed I don't loose much speed until it gets super hot AND humid. Ran several times this year when it was almost 90 and was still with in 1 MPH of my record speed. And I'm carbs.
skaterjim
03-03-2006 11:08 AM
challenger
Sonic
4
04-16-2005 07:52 AM
dreamer
04-11-2005 05:32 PM
Maximus
02-12-2004 07:59 AM
HiPerf2000
Sonic
1
03-10-2003 02:57 PM
