-   Sunsation (https://www.offshoreonly.com/forums/sunsation-43/)
-   -   2008 Sunsation 288 Step Hull (https://www.offshoreonly.com/forums/sunsation/373468-2008-sunsation-288-step-hull.html)
wsinglem 04-18-2022 08:57 AM
Almost that time............ :boat:
wsinglem 04-20-2022 07:31 AM
Originally Posted by wsinglem (Post 4813813)
Anyone running the tubes?? Would like to know if it made a difference.
Ritt 05-11-2022 08:06 AM
Where can I get a set of tubes at. Mine are long gone.
I could make a set. What are the dimensions?
waterman 05-11-2022 08:29 AM
Hello,
I had to go under my boat and match it up by trial and error. I talked the the factory and they don’t have the template anymore.
Ritt 05-12-2022 11:56 AM
Originally Posted by waterman (Post 4831818)
Hello,
What dia tubing did you use?
waterman 05-12-2022 12:08 PM
Hello,
1/2 inch pvc. Doing the bend in the tube was tricky, and I used 4200. I wish the factory would have used something stronger.
wsinglem 05-14-2022 08:56 AM
Originally Posted by waterman (Post 4831950)
Hello,
Any pics we could see please. :boat:
wsinglem 05-23-2022 05:11 AM
https://www.speedonthewater.com/suns...lake-st-clair/
Ryan8886 06-01-2022 06:01 PM
Can’t speak for the newer hulls….but my
old “‘94 Dominator (just a straight delta pad boat…no steps or anything like you’ve got pictured there) took some tricks to get on plane. Anything less than fully tucked in drives and tabs maybe half way down or the props would just blow out. They were standard 25 pitch props if I recall correctly. Even still, it required a little back and forth on the sticks for them to bite in and get up on plane. Nice to see they’ve at least made improvements there.
wsinglem 06-16-2022 12:08 PM
Anyone got a pic of the tube???
