The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 07-17-2007 | 02:59 PM
  #7441
wstultz's Avatar
Social Distortion
1.5:1 is a higher gear ratio...right ? which means the engine makes 1.5rpms for every 1 rpm on prop shaft, wouldn't this be less top end ????? Hmmmm Hmmmmm ???
Less RPM's
sorry, less stress
wstultz is offline
  #7442
Originally Posted by wstultz
Suckered???? I believe you stole it from me.
You want it back ????? Thats what I thought .....
Trojan-man is offline
Old 07-17-2007 | 03:00 PM
  #7443
Less RPM's
aristocat does 70mph at 4000 rpms......that sounds good to me....
Old 07-17-2007 | 03:02 PM
  #7444
wstultz's Avatar
Social Distortion
His engines are king kong to your buggs bunny.
wstultz is offline
  #7445
Less RPM's
sorry, less stress
Huh ??? I think I need to hear it from a retard that knows bravos not arnesons
Old 07-17-2007 | 03:03 PM
  #7446
BY U BOY's Avatar
this boat is a true 24' (no platform or beak), it weighs 4100 lbs. and has a crate motor merc 454. I don't know where to start with the prop ???
also, I have noticed that they make bravos with a 1.5:1 ratio and a 1.35:1 ratio. Excuse my inexperience, but what is the difference ...I am guessing the 1.35:1 would be higher top end. If any of you answer this by putting .15:1 I am just going to kill you.
the 1.35:1 is if you have alot of HP and run out of pitch sizes on a 1.5:
You are going to need a 23p prop maybe have a little work done to it depending on the HP of the create motor.
BY U BOY is offline
  #7447
does black betty like your analogies too ??
  #7448
wstultz's Avatar
Social Distortion
That's what you need, just slap an Arneson on there.......and I am retarded when it comes to gear ratios.
wstultz is offline
Old 07-17-2007 | 03:05 PM
  #7449
wstultz's Avatar
Social Distortion
Maybe Rik at Arneson has an old #6 at the shop he can sell to you cheap.
wstultz is offline
Old 07-17-2007 | 03:06 PM
  #7450
BY U BOY's Avatar
Stick with the 1.5:1 you have no need for a 1.35
BY U BOY is offline
