The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 09-07-2007 | 05:08 PM
  #9611
BY U BOY's Avatar
I think your mechanic should stick to working on stoves...and fridges....
why would you say that.
He knows his chit.
BY U BOY is offline
Old 09-07-2007 | 05:12 PM
  #9612
bigandy's Avatar
Two words: Lakeview Marina, it is where Marine Max sends there new customers and where they fill up their own boats. It's $2.99 a gallon but maybe because its real gas and not cream of corn!!!
bigandy is offline
  #9613
tomtbone1993's Avatar
He knows his chit.
Because after Ticfaw....Spik1 came over to club 105 with my engines on a hose runnin like chit. He poored in the Heet and you could hear the engines clear themselves out. You could also see the exhaust clear its self out. It is good chit
tomtbone1993 is offline
Old 09-07-2007 | 05:13 PM
  #9614
92 or 93 Octane??? Is this also the same marina that charged me $20.00 vs. $7.00 to launch my boat cause I had an extra axle on my trailor???
Old 09-07-2007 | 05:26 PM
  #9615
bigandy's Avatar
As far as heet goes, and please no one debate this it has been studied. It does not work to help to much ethanol, it helps water in fuel. The only way to help to much ethanol is dilute it with good gas.
The ethanol is a great cleaner, lower octane than gas but the problem it is causing people is older technology was not made to accept it and it makes fuel filters fall apart, gaskets in fuel pumps fail and it absorbs the water that has been in the bottom of your tank for twenty years and also cleans all the sludge and crap from fuel lines and tanks and stops up the needle and seats and venturies in carbs and injectors. it is bad stuff but what can you do. Tbone i would add real octane boost, go get some AV fuel and put it in.
bigandy is offline
  #9616
BY U BOY's Avatar
no they charged you 20 bucks cause its a beak
BY U BOY is offline
Old 09-07-2007 | 05:28 PM
  #9617
BY U BOY's Avatar
Thank you Andy that is the point i was trying to make. Heey is alcohol based there for making the problem with the fuel worse.
BY U BOY is offline
Old 09-07-2007 | 05:30 PM
  #9618
BY U BOY's Avatar
I may be taking a rd trip soon.
please do not copy this link i want to keep this one hush hush.
I have to be happy with this one for a while. There is also a cig bullet at LOTO that i like.
BY U BOY is offline
Old 09-07-2007 | 05:31 PM
  #9619
Interesting.....so you are sayin the heet did its job in the spring...My tanks should be more than clean...now I need to bring the octane back up??
Old 09-07-2007 | 05:33 PM
  #9620
I may be taking a rd trip soon.what do yall think.
http://adcache.boattraderonline.com/6/2/8/87999628.htm
There is a picture of that boat on the FPBC website. The transome is atleast 10 to 15 feet out of the water
