The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 09-07-2007 | 05:44 PM
  #9631
BY U BOY's Avatar
I am sure volvo and Merlin have the same recommendations on Octane level
Were do I sign up to pay $2.99 for 87 Octane
I wish i could burn 87
BY U BOY is offline
  #9632
bigandy's Avatar
Originally Posted by spk1
I know most mechanics are very much against solutions in a can, and in most cases they are correct, but from a molecular level, I have found heet to be effective, Its contains methanol and methanol is more effective in reducing power loss from certain fuels because of some thing called "latent heat of vaporization" , this is why I believe it has worked so well when mixed with a stagnant ethanol. both gasoline and ethanol has more power per unit volume than methanol, but the latent heat of vaporization in methanol gives it much more efficient burn, and less power loss than that of ethanol.
Im not saying heet is an end all say all cure, but it can get you out of a jam, with out having to drain your tanks in most cases.
As with ethanol methanol is an alcohol, and you will need to keep an eye on most of your rubber coated fuel parts, alcohol dries them out, and in extreme cases it eats them, so when using heet use just enough to get the crap out,, then ur good.
What spick is trying to say is the change of state from liquid to vapour at constant temperature also requires the input of energy, called the latent heat of vaporization. This implies that while a liquid undergoes a change to the vapour state at the normal boiling point, the temperature of the liquid will not rise beyond the temperature of the boiling point.
The latent heat of evaporation is the energy required to overcome the molecular forces of attraction between the particles of a liquid, and bring them to the vapour state, where such attractions are minimal.
The definition of the specific latent heat of vaporization is
'The specific latent heat of vaporization is the amount of heat required to convert unit mass of a liquid into the vapour without a change in temperature."
I hope this clears up any confusion....
bigandy is offline
Old 09-07-2007 | 05:47 PM
  #9633
BY U BOY's Avatar
so my flux capacitor should be fine
BY U BOY is offline
Old 09-07-2007 | 05:49 PM
  #9634
bigandy's Avatar
if your boat could go 88 miles per hour maybe it would be!!!!
bigandy is offline
Old 09-07-2007 | 05:54 PM
  #9635
tomtbone1993's Avatar
Good info.....
I will be at Club 105 tonight if anybody wants to show up and hand me beers, and tell me how "you" would do it vs. the way I am doing it
tomtbone1993 is offline
Old 09-07-2007 | 05:55 PM
  #9636
got a link?
can not pull it up at work...florida powerboat club...Destin run 5 or 6 years ago
  #9637
BY U BOY's Avatar
How do you guys think a 29 will handle conroe and the bay??????
or should i take a closer look at the bullet?
BY U BOY is offline
Old 09-07-2007 | 05:57 PM
  #9638
Bullet will handle the water better....but twin 350 should be very reliable
Old 09-07-2007 | 06:06 PM
  #9639
BY U BOY's Avatar
i also have to think about the weight of the bullet and if i can get it up the launch.
BY U BOY is offline
Old 09-07-2007 | 06:12 PM
  #9640
Ok, I guess the chemical convo should take place at outback,, where google is not readily availible,
We will be there at 6:45.
spk1 is offline
