trailer toolboxes
Old 04-17-2005 | 06:51 PM
traviss's Avatar
Default Re: trailer toolboxes
finished painting my trailer a few days ago.. got the boat back on it today Here is my home depot trailer box
traviss is offline
Old 04-18-2005 | 07:56 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
traviss, looks GREAT!!
Sydwayz is offline
Old 04-18-2005 | 08:29 AM
I agree!
How did you attach the diamond plate?
Rippem is offline
Old 04-18-2005 | 06:18 PM
traviss's Avatar
thanks guys the diamondplate is rivited to the trailer. In between the plate and trailer I used rubber washers to isolate the aluminum from the steel. Came out better then I thought
traviss is offline
Old 04-19-2005 | 06:13 AM
Nykamp's Avatar
Weather Guard makes awsome tool boxes I have put them on my last 4 work trucks. If my myco didn't have factory boxes I would in stall weater guards on her. They hold up very well. Steve
Nykamp is offline
Old 04-21-2005 | 11:15 AM
dukenrock's Avatar
I should have my toolbox installation completed today. I found themn at a semi wholesale shop. Black powder coated with a heavy duty hinge and latch assembly. Prices were very reasonable. (36"-$209.00//24"-161.00) I'm not going to drill through the rails, instead I'm having front and rear brackets made up and then I'll run bolts above and below the frame, through the toolbox. I am also going to install diamod plate across the front and wrap in on top. This should eliminate the stone bruises on the fron of the boxes and allow me to step on top of the box without scratching them. Should look good too. I'll post some pics when I finish them later today.
dukenrock is offline
Old 04-21-2005 | 02:30 PM
please do!
Rippem is offline
Old 04-21-2005 | 05:18 PM
dukenrock's Avatar
Almost done...
Attached Thumbnails trailer toolboxes-copy-copy-p1010011.jpg   trailer toolboxes-copy-p1010006.jpg   trailer toolboxes-copy-p1010011.jpg
dukenrock's Avatar
more...
Attached Thumbnails trailer toolboxes-copy-p1010015.jpg   trailer toolboxes-p1010005.jpg   trailer toolboxes-p1010006.jpg
Old 04-21-2005 | 05:20 PM
dukenrock's Avatar
few more...
Attached Thumbnails trailer toolboxes-p1010007.jpg   trailer toolboxes-p1010008.jpg   trailer toolboxes-p1010009.jpg
