Gmc 2500 Diesel ?? Or Ford
Old 02-21-2006 | 04:18 PM
hammer01's Avatar
Default Re: Gmc 2500 Diesel ?? Or Ford
I Have Had 3 Duramax's And 1 Dodge Cummins. The Gmc's Tow (my Boat And Trailer At About 14k Lbs) Better And More Comfortable Than The Dodge, But The Dodge Got Much Better Fuel Economy And Seemed To Have More Pulling Ability. In General, If You Travel A Long Distance For Towing As I Do (sometimes 7-8 Hours Towing The Boat One Way) The Gm Product Is A Much More Comfortable Vehicle With Many Fellow Travellers To Vouch For This. Not To Mention, There Is More Room In The Gm.
hammer01 is offline
Old 02-21-2006 | 06:17 PM
You guys are most helpful , kinda knew alot of this before , just needed a kick in the butt to get me goin , thanks so much ,
elroy521 is offline
Old 02-21-2006 | 09:36 PM
I have what I belive is a good question, is the size of the tires stock or the gearing of the transmission on the Ford what allows it to run 4.10 gears or something else? The GM only comes with 3.73, what's the difference? I run about 2500rpm with the stock 245's on my DMax at 75MpH, is this about the same with bigger tires? How about the Ford, what kind of RPM do you see at 75mPH? Ken.
FROGMAN524 is offline
Old 02-22-2006 | 06:02 AM
hp500efi's Avatar
Member #9
My F250 (7.3 PSD) (3.73's) with slightly bigger tires than OEM (285's) runs 75 at about 2050 rpm.
Member of the Liquid Jungle
hp500efi is offline
Old 02-22-2006 | 09:34 PM
oK, then having the torsion bars raised and putting on 285's would probably drop that rpm. Thanks.
Old 02-23-2006 | 08:40 AM
Tim G.'s Avatar
Performance Boat Center
Frog,
I did the t bars and 285s on my '04.5 2500HD.
RPMs dropped on the highway, but I could feel the difference in accelleration.
Doing it again, I think I would put 265s on.
My truck is the 5 speed, not 6 speed.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 02-23-2006 | 09:16 AM
Wobble's Avatar
SORE MEMBER
my 06 runs 79 at 2000rpm in sixth. 2500hd stock tires
Wobble is offline
Old 02-23-2006 | 10:30 AM
Tim G.'s Avatar
I know that that's still lower than my 5 speed ally with 285s.
We have a dually with the 6 speed. 80 at 2k sounds about right.
Just pulled 21,000+lb with it today! No problem. Bone stock everything.
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
Old 02-25-2006 | 12:03 AM
I Get 9 Mpg Towing Over 10000 Lbs With A 03 Ford 250
With The 6.0 .is That Avg...truck Pulls Great...i Have The Superchips Programer And Tried It With And With Out..didnt Seem To Matter
chad1 is offline
Old 02-25-2006 | 03:49 PM
Harper220's Avatar
Originally Posted by Troutly
I have a 2004 Ford 6.0 that was built in Feb 2004. I love the truck
But, with that in mind, I would not hesitate to by the GM Duramax.
I even like the Dodge Cummins, but I still think their crew cab is a joke.
Duramax is ~smooth & quiet~ with a little background whistle...
Cummins is obnoxious sounding...
Harper220 is offline
