Towing capacity question??????
Old 05-06-2006 | 04:40 AM
  #151
flatout's Avatar
Default Re: Towing capacity question??????
sleeper dave you and i belong on another site this one was designed for above average income folks. (go to hotboat much friendlier crowd there) Everytime I ask a question here I get slammed. Oh and heaven forbid you say you get better milage in your truck than someone else, or that ford or chevy is better than the other people around here loose sleep over that stuff, lol.
for the guy that started this post, believe nothing of what you hear and only half of what you see.
flatout is offline
Old 05-06-2006 | 10:26 PM
  #152
Originally Posted by Chris Sunkin
Your manufacturer's GVWR dictates what your vehicle is registered at. Under 26,000 is non-CDL. 26,001 and up is CDL. They're going to assign it's registered weight to what the GVWR is on your paperwork. This doesn't apply to an RV or to a non-commercial bus which is considered to be an RV.
Also, you can't register a vehicle that is rated 26,001 and above as a non-CDL vehicle. USDOT prohibits any changes to the Mfg. GVWR.
Interestingly enough, DOT limits a non-CDL driver to a loaded trailer not more than 10,000#. I'm afraid to ask if non-commercial's are exempt.
So.....I registered it for 26g....was that wrong...I thought I was responsible for what is in tow also??...weight wise on registration.....oh boy!..and since it said that tow capacity gross weight...I thought this was the way to go..????????...make sure you look at my sticker in post 145!!!!
Byrdman is offline
Old 05-06-2006 | 10:28 PM
  #153
JCPERF's Avatar
JCPERF is offline
Old 05-07-2006 | 08:04 PM
  #154
stecz20's Avatar
your fine.... if your trailer weight with boat is not near 26,000 you paid a little extra than needed.. other than that you did the right thing... do you know what the boat and trailer even weigh???
stecz20 is offline
Old 05-07-2006 | 08:27 PM
  #155
I wanted to know if that was the correct thing to do...26 or 17500....what is the law..
Byrdman is offline
Old 05-07-2006 | 08:32 PM
  #156
offthefront's Avatar
Originally Posted by nolimits
F150 ( beautiful vehicle ) is limited to 8200 - 9500 lbs. for towing. THe 3/4 ton and 1/2 ton is a payload thing, I think
I heard somewhere that ford was going to put a diesel in the 150's ... a baby diesel ... ..... I have had the same thoughts about my Formula less than 12K ... and ONLY to pull the boat out at the ramp and then 2 miles (flat) to the house ... My dad has a 99 PS ford 250 ... 49K miles ....I'll prob be better off with that than a 150 .....
offthefront is offline
Old 05-07-2006 | 08:58 PM
  #157
stecz20's Avatar
bryd, the dmv will never tell you what you can reg a truck or trailer for.. they dont care, who does are the troopers, and county cops.. the more you reg a veh for teh more dmv makes, its all good to them... the veh will tell you what is legal... all you need to know it this..
Gross Combination Weight Rating....... (GCWR)
this is the maximum allowable weight of the towing vehicle and the loaded trailer including cargo, passengers and fuel that the vehicle can handle safely without risking costly damage.. The measured GCW must never exceed the GCWR, which in your case is 26,000...... if you reg for over this you are wasting your money cause you have the wrong tow veh, if you wreck you wont get paid... the only thing that over doing the GCWR does for you is that it insures that you wont get an over weight ticket, thats it...
you did the right thing, if you are close to that weight, which is 26,000.. if you are well below that, and i dont see how you can be you just wasted your money.. how much did it cost you to reg it??? 60.00
stecz20 is offline
Old 05-07-2006 | 09:00 PM
  #158
stecz20's Avatar
at 17,500 you would have problems... you did the right thing.....
stecz20 is offline
Old 05-07-2006 | 09:16 PM
  #159
stecz20's Avatar
GCW is the weight of the loaded vehicle, plus the weight of the fully loaded trailer. it is the actual weight when the vehicle and trailer are weighed on a scale.... just go to a public scale and find out what you are at....
stecz20 is offline
Old 06-10-2007 | 02:08 AM
  #160
back in 1974 i towed a 42 cig with the gremlin, no problemo.
FROGMAN524 is offline
poolshrk
29
07-28-2007 01:25 PM
oreo11zeus
2
03-19-2007 08:47 PM
Fast Forward
22
02-09-2007 09:54 PM
yss
5
07-06-2005 08:38 PM
two-air
09-01-2004 07:06 PM
