Ford integrated brake controller >
Old 08-07-2006 | 07:51 AM
KiloKat's Avatar
KiloKat
Default Re: Ford integrated brake controller
We use the intergrated brake controller all of the time while pulling various trailers with electric over hydraulic. No problems.
KiloKat is offline
Old 08-07-2006 | 10:03 AM
J.B. Marshall's Avatar
JB Marshall
KYE,
I have a 2006 F250 I purchased in April and it has the new in dash brake controller. I installed the Carlisle brain box on my trailer (Manning tri-axle) and it works great (http://www.carlislebrake.com/spec_hb...er-module.html). I pull a 382 Fastech and it stops it perfectly. Cost was $80 and you wire it in to the four wires after the plug. Very easy follow their directions, I do recommend soldering the wires together as opposed to crimp connectors.
Good Luck,
JB
J.B. Marshall is offline
Old 08-12-2006 | 01:42 PM
Scott B's Avatar
Check the voltage @ the plug on the rear of the truck with the brake fully depressed, max gain. There were some early units that did not deliver full voltage...
I have towed extensively with the Tow Command system now (59k miles in two trucks) and love it over anything ele we have used. Intuitive, doesnt jerk the truck around, just a pleasure to use. Prodigy I just installed in a truck is pretty close to the performance, but a bit jerkier...
Scott B is offline
Old 08-12-2006 | 08:52 PM
I installed the Hayes, Genesis unit and tried it out. First of all, the included wiring harness worked great. All I had to do was to unplug the harness from the ford controller and plug the other one in. The unit fit perfectly into the space next to the contoller after cutting the back. An honest 15 minute job. I took it out for a spin. The controllers felt similar. The only advantage was that the genesis seemed to supply more power at tip in. The dash had a TBC fault that would annoyingly appear til it was reset. I'm going to take a long trip with it and check. Put this one in the OSO bank. The Ford controller, if compatible with your trailer is as good as it gets.
SkiDoc is offline
Old 08-16-2006 | 06:00 AM
horsplay's Avatar
have the built in ford controller in 05 f55o with electric over hydraulic ,works great except experience bad jerking action at very slow speed occasionally when coming to a stop or driving in stop and go traffic , any suggestions as to remedy, this has been a dangerous situation sometimes.
horsplay is offline
Old 09-01-2006 | 07:32 AM
horsplay's Avatar
hydraulic system is brakerite anybody no the fix for this
horsplay is offline
Old 09-01-2006 | 05:13 PM
Scott B's Avatar
Are the brakes jerking, or is it a rough downshift in tow-haul mode? Found some water in my trany that was causing an intermittant rough 2 - 1 downshift.. Flushed the tranny and all is good...
Scott B is offline
Old 09-02-2006 | 10:08 AM
horsplay's Avatar
no its not the truck definetely some problem with trailer or ford controller? brakes on trailer are fine and adjusted correctly
horsplay is offline
Old 09-03-2006 | 11:35 PM
I had the same problem with my 5th wheel trailer. Turned out to be a slight amount of play in the neck of the trailer. So make sure you don't have a small amount of play anywhere in your hitch or trailer.
steve1k99 is offline
Old 09-04-2006 | 07:57 AM
horsplay's Avatar
thanks ,im actually getting that fixed now, i had alot of play ,while your driving trailer would go back and forth like a pendulum , very annoying, did that cure your problem?
horsplay is offline
