The Real Towing Capacity???
Old 02-08-2007 | 12:53 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default Re: The Real Towing Capacity???
Originally Posted by Dock Holiday
No, not at all.
It distributes weight to the front of the truck instead of it all being carried on the rear axle.
I know what it does, and you dont need it to pull the max....maybe brake w/ max load. In some instances the trailer is well balanced and you are within max tongue weight w/o the need for a WD system. Max tow capacity is a best of both worlds taking into consideration motor/trans, axles and wheels etc. I am within the tongue weight, but not the trailer weight in regards to not needing the WD system.
tblrklakemo is offline
Old 02-08-2007 | 08:13 PM
Expensive Date's Avatar
Originally Posted by Sydwayz
The current Formula 292 is only offered with twin SBC, not BBC; which I believe is what Expensive Date has; could be wrong.
You are correct
Expensive Date is offline
Old 02-09-2007 | 09:54 PM
Originally Posted by UNSANE
I drive a Titan and tow a 29' Fountain. Fully loaded down with fuel and trailer, that's around 8000lbs. I tow on the highway and get 11-12 mpg at 65mph and have to drive long distances regulary. I've been in more than one situation where I had to get on the brakes and it stopped/slowed down.............real quick. I've never had to put the brake pedal to the floor....With an 8000lb load, it's 0-60 time crushes an F150 by a full 6 seconds, so it's by no means a wimpy truck. (neither is an F150)
And yes, I've had it with the Nissan/Toyota bashing. Grow up people!!! Been watching that thread about the new Tundra. Not one thoughtful critique or arguement against it. Just borderline racist and biggoted comments are all I'm reading and all of the sudden people are having Iwo Jima and Guadalcanal flashbacks as if they were there. My Uncle Bob was at the latter, and although he hated Japanese until his last day, he did RESPECT them.
I don't read of anyone calling someone a Nazi for driving a Porsche, BMW or Mercedes.....
Fast forward, here is my advice: Forget names and just go check out a narrowed down list that you make based upon your requirements. My dealer was even going to allow an extended test drive with my boat if I so desired as well. Check out that possiblity. Maybe a diesel in the cards??? Who knows??? Buy what you think is right, (capitalism...yay!)not what the neighborhood thinks you should buy. (socialism...boo!)
Well said man, well said.
ThirdBird is offline
poolshrk
29
07-28-2007 01:25 PM
hugetime1
159
06-10-2007 02:08 AM
oreo11zeus
2
03-19-2007 08:47 PM
yss
5
07-06-2005 08:38 PM
two-air
09-01-2004 07:06 PM
