Would you use an aluminum ball mount?
The picture shows it in the drop position. In that configuration, the load from the trailer hits the ball shank pretty close to the receiver with a small lever arm. If you flip it upside down to make a rise, and invert the ball, you've more than doubled the lever arm. I'd be wary.
Brian, which one isn't solid, the adjustable or fixed? I held these things in my hands at SEMA and they're solid; machined out of a billet block. I'd say the fixed height unit weighs more than a comparable hollow steel piece. I do like that hitch ball you linked; THAT would be worth the money.
I didn't think I'd get this much feedback but glad I did. I haven't given up on wanting an aluminum drawbar, but I'm considering other options.
Thanks.
These drop hitches scare the crap out of me. I can't for the life of me understand how in the world these guys get these things certified and DOT approved for 10,000#, 1500# tongue weight.
I don't know what the hell kind of aluminum they're using, I'm sure it's a common commercial grade, but even if I assume it's a high-strength grade something like a 2024-T4 or a 7075-T4, with Ftu's approaching 70,000psi, there's no way in hell they can have positive margins......Even in a simple load case, like 10,000# forward (light braking = 1G), 1,500 down, and a slight side load for good measure, I'm seeing negative margins which equals failure!
Add to this the fact, that these things live a hard life with dents, scratches, corrosion, stress corrosion cracking (especially in aluminums), fatigue, dynamic cyclical loading, the occasional crater pothole, etc., etc.....
Not for me thanks.
Not for me thanks.
Some jackass stole all of the clip-pins off of the adjustable hitch on the OSO F-650 at a Poker Run, with the 38PP behind it. Thankfully the missing parts were noticed prior to departure.
Those shiny, polished aluminum hitches are nice for the landscaper with the 1-ton truck with the 8-inch lift pulling a 1400# trailer, but for anything substantial, get the biggest nastiest hitch you can find.
Don't let that be the weakest link.
And I agree, I wouldn't want to test that adjustible height setup at full load rating.
