Z71 with 6.5 diesel
Actually, the big problem with the '94 was the injection pump as it was the first year they went all electronic on it. I had mine in the shop about every 70K miles getting a pump done on it. There is a forum dedicated to the 6.2/6.5 diesels with lots of great info.
I had my '94 crew cab 3500 for 6 years and put 245K miles on it. Still one of the best trucks I've owned. Just don't get used to towing up hills fast.
I had 2 6.5 3/4 ton Suburbans. Other than sounding like a popcorn machine, I had zero problems with them.
Pretty rare truck you've got there. Have only ever seen a couple of them in 3/4 form, even less as a half ton.
Tow in 3 if you have an automatic- NOT OD.
You will have to beef the rear springs and a heavier hitch.
They mostly put 8500 lb hitches from factory - not enuff for you.
I would say the sonic is at least 8000 lbs plust trailer- they are known for being a heavy boat. Alumimum trailer will help. Good luck.
Wannabe
Wannabe
Thanks guys, I had read on a couple of different sights about the injector pump being a problem. Actually, I didnt read anything good about them. I`m glad to hear at least a couple good words. It was cheap as hell and if it holds up mechanically it should fit the bill!
Wannabe
Wannabe
most people think they know but actually have no idea what their boat wieghs.......if you had of asked me before I would have said boat and trailer wieghed 8000
changed exhaust and took 200lbs off that number though!!
