heavy towing with f450
#61
He has driven my SportChassis with the MBZ motor and he said it is much better performance than his F650 with the C7 motor. He keeps looking for upgrades that would add a ton of HP to the C7. He hates that motor in his truck. He has even considered putting in a powerstroke or something which would be a mistake.
#64
#65
Registered User
The FL-50,60,70 mediums were concurrently called Business Class for a while in the late 90's and early 2K range. Then they dropped the FL and it became the Business Class M2 with the more streamlined cab. The Sportchassis is the M2 built specifically for conversion. You could order the same truck and equip it exactly the same as the Sportchassis they sell to converters.
#66
Registered User
My preference is for the purpose-built truck. The Ford and GM use the same cab as their light-duty pickups. Compared to a FL/KW/Pete/Int'l, there's much less overall room, especially headroom. You see many of the Ford/GM's with bubble roof extensions. If you have an air-ride seat, you'll need it. If you're over 6', get used to smacking your head. Plus, you sit with your legs out in front like a pickup. In a medium, you're sitting upright, as you would sitting in a chair.
The interior is one of those chocolate/vanilla things. The service availability is a tangible asset. That is a big deal for us as we have trucks in 5 states and if they aren't on the road, we're losing $$. It's a rare occurrence though. It's not like we have a fleet of OTR tractors with 1MM+ on them. These things are exceptionally reliable. They're not even broken in until 80K+ and I've never had an expensive service issue under 400K- they'tre usually done before that anyway. We maybe have a couple of unexpected issues a year.
If you equip it properly, there is no bad choice. If you buy a used C&C that used to be a delivery truck, don't expect the same performance & comfort as a purpose-built toy hauler.
As far as comfort, the Ford s I've driven seemed very pleasant. It's pretty much the same stuff under the cab, regardless of the name on it. Ford doesn't make anything but the cab. Neither does anyone else. If you buy equivalent leaf-spring or air-ride chassis', they're going to be virtually identical in comfort and capability.
#70
Registered User
I can assure you, it's a marginal setup in perfect conditions. When the weather turns bad or something unexpected happens, you'll spend those brief seconds wishing to God you had more truck.
If you wait long enough, someone will happen along and tell you exactly what you want to hear.
There have been more than a few people on here that have owned multiple combinations of boats and rigs in that weight range that have in almost all cases said there's a tremendous difference between the 450 and the medium.
