Surge brake question...
I couldn't agree more, and I'll add that you can't control them independently or adjust them relative to the truck... but on a boat trailer, you're kinda' stuck with them. Electric brakes hate getting dunked in lakes, and most of us aren't using trucks with air brakes.
Registered User
Master cylinder is probably rusted/froze up. I know when I was going through my trailer brakes/bearings this fall I found leaky grease seals/grease filled drums and worn to the lining shoes. Replaced the bearings/seals and shoes and found rusted solid wheel cylinders, changed those and tried to bleed I found dry lines and a rusted/frozen master cylinder. Luckily I keep my boat racked so the trailer doesn't get much use but from what I can tell the trailer brakes hadn't worked for awhile (just bought the boat last year). So I bought a new master cylinder for the time being, but I'll probably do a disc conversion next year. Eagle trailer/Dico brakes btw.
You know, I guess I'd have to admit I haven't personally tried using electric brakes on my boat trailer... but I'd sure love to, they work SO much better.
You've got me seriously considering a swap.
Anyone else have electric boat trailer brakes and no issues with getting dunked in the lake? How about saltwater? I generally avoid putting my boat in salt but I might get a wild hair someday.
If used only in freash water, electric brakes are doable. But the magnets in the wheels rustup very fast, maybe if flushed each time they may last a while longer. I would opt for the ele over hyd with disc. The best of all worlds and just flush after that salt water dunkin..................
happy hours
4
02-25-2007 08:26 AM
TP121
5
06-06-2006 09:30 PM
