Eagle trailer redo
Old 07-31-2008 | 09:28 PM
Wow, inspiring. Makes me want to redo my trailer! So how much do you have into it so far?
MILD THUNDER is offline
Old 07-31-2008 | 09:34 PM
that's as far as I've gotten.
still have to:
wire the batteries
mount the aux 7 pin receptacle that is part of the SD harness on or in that plate. You can just plug your 4-way into this with and adapter and be done with the light wiring. I have a dual (7 and 4 pin on the side) plug on the truck so I could just plug them both (7 and 4 pin) into the truck
waiting on six brake hoses. bleed.
LED's coming
get it back on the ground and polished
make up my mind on toolboxes
install controller in the truck.
still got some work to do...
Rippem is offline
Old 07-31-2008 | 09:45 PM
good prices (great prices actually) on parts...
doing all the work myself as usual...
$2500 give or take $100
that's
six new tires
the Kodiak 13" discs
bearings, races, seals
Full on BR SD EOH system w/2 batt. breakaway
some new brake hoses
LED lights
100' bunk carpet
a couple pieces of lumber
the aluminum sheet
truck side brake controller
small misc.
the paint on the trailer is excellent as it has low miles and is always inside...
but, like the tires...and the drum brake problems...
six years old and time to get ahold of it's condition and safety.
I'm gonna have this boat along time!
Rippem is offline
Old 07-31-2008 | 10:07 PM
Originally Posted by Rippem
six new tires...
I've been acquiring those B'stones since late last year.
0 mile take-offs and new spares from under GM HD's.
I have $50 apice in them. They are a good LR E tire. The straight rib tread pattern will run cooler and channel water well (not that I want to get caught in the rain!).
Much moreso that the light truck LR E block tread "all terrain" tire that came stock.
Rippem is offline
Old 08-01-2008 | 04:49 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
How much clearance do you have between the bottom edges of brake pads and the rotor? On my 8 lug axles, Kodiak # 250 calipers, (same as your setup it appears) the outer pads have the worn a groove into the rotors hubs because there is no clearance. I removed the pads and ground the steel down a bit, almost to the pad itself to gain some clearance, but they still rub. Eagle suggested the grinding themselves when I called to question this. The calipers have also grooved the rotors a hair. But just enough to remove the paint. Not the 1/16" grrove like the pads have done.
Pics: http://www.offshoreonly.com/forums/s...ghlight=kodiak
US1 Fountain is offline
Old 08-01-2008 | 07:57 AM
Thanks for the heads-up, I will look more closely at this today and post.
I noticed there was not alot of clearance when I assembled them.
Rippem is offline
Old 08-01-2008 | 08:28 AM
I have clearance average 1/4"
Rippem is offline
Old 08-04-2008 | 08:22 PM
more progress...
after &*#@ing around with sheet metal screws and considering other ideas, none of which I was happy with...
I drilled and tapped 3/8-24 to secure the aluminum sheet to the frame. Also spaced it down with some more chit out of one of the magic boxes...more plastic spacers.
everything is thru-bolted
mounted the aux plug in for the lights...
Attached Thumbnails Eagle trailer redo-100_0170.jpg   Eagle trailer redo-100_0171.jpg   Eagle trailer redo-100_0181.jpg
Rippem is offline
Old 08-04-2008 | 08:26 PM
had to finish the supplied end and make some wires up for the batts...
good bare metal ground for batts
Attached Thumbnails Eagle trailer redo-100_0174.jpg   Eagle trailer redo-100_0177.jpg   Eagle trailer redo-100_0179.jpg
Rippem is offline
Old 08-04-2008 | 08:33 PM
I didn't like the breakaway cable straight and too long.
cut the plug end loop off and attached the original coil-cable from the surge E-brake.
I have brake lines and P3 coming Wed.
I am waiting to put the wheels/tires back on and put it on the ground 'till after I get them bled
need brake lines...
my order didn't go out for a week
and they are charging $28 frieght for 7 lbs of stuff from Mass to NY..
I expressed my dis-pleasure
Rippem is offline
