Performance Upgrades For 3126 Cat Motor >
Old 09-24-2008 | 03:51 PM
puder's Avatar
speel chekk this fokker!
Originally Posted by Bottomfeeder
I had a 2001 Freightliner Sport Chassis with a Cat 3126 and the previous owner installed an Edge tuner and that truck hauled A$$!!! Just make sure you watch your EGT,,,
I too have a edge box in my 3126 set to "2". I tried "4" and it had tons of power but I was seeing EGTs higher than I was comfortable with when pulling my 50' race rig up long steep hills.
Pardon me, while I whip this out!
puder is offline
Old 11-11-2008 | 06:35 AM
Had my 3126 cat motor at mustang yesterday and they said it was rated at 300hp and 860ft lb and at the dealer they won't turn it up anymore than that,but on here I have heard of edge programmers but I have been unable to find one, anyone know where I can get one?
insanity342 is offline
Old 11-11-2008 | 11:06 PM
My Edge programmer was allready installed in my Freightliner when I bought it,,did you try contacting Edge directly?
Bottomfeeder is offline
Old 11-13-2008 | 05:23 PM
Originally Posted by insanity342
GREAT BUT WHAT ABOUT C7 OR 3126
There is a company here that sells its Kenworth W900L Trucks with C15s every couple years with low miles and perfectly maintained. It would be cheaper and more reliable to buy a truck around the motor than just the motor. These trucks look like show trucks and their mechanic is a neat freak. Medium duties don't do well with 15 Liter Diesels.
pookie is offline
Old 11-13-2008 | 10:54 PM
Did they say why? They have an upgrade to 330/960.
Hot Knots is offline
Old 11-13-2008 | 10:56 PM
Originally Posted by beertruck
looking to put this hydraficient water fuel cell system in my F650, I will let you know next month after the instal how it works
http://hydraficient.com/
So what are the numbers you're seeing?
Old 12-11-2008 | 08:15 AM
ChrisK's Avatar
Moderator
I just had to replace the high pressure oil line on the drivers side of the motor, leads from the pump to the head. If anyone needs to do this send me a message and I will send you the "tool" I had to make to get he pressure switch out. You need to grind a wrench down to get it out. The old line is rubber and CAT makes a new retrofit kit that makes it a hard line.
ChrisK is offline
Old 12-11-2008 | 07:59 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Beertruck, any update yet on your truck yet?
mcraymond3 is offline
Ona-Mission
21
09-18-2008 12:47 PM
LubeJobs42
11
01-01-2008 05:22 PM
260SX
Powerquest
2
08-13-2007 02:50 PM
