Trailer barake question,EOH or electric >
Old 01-16-2009 | 01:45 PM
On Time's Avatar
Once you are set up go to a large empty parking lot and set up your brake controller, instructions in hand, and you will be fine.
On Time is offline
Old 01-21-2009 | 09:44 AM
JasonSmith's Avatar
Originally Posted by cig1988
[/U]
Not the case...a "jacknife" situation will result if you do not keep the tension between the towing vehicle and the trailer. Easiest way to explain is to pull a rope with a weight attached. What happens when there is no tension? The weight/momentum/slack will keep rolling and or push the towing vehicle. The trolley lever on the controller is used for this pupose as in class 8 tractor trailers.
The brake lever is for improperly adjusted rear brakes. Improperly adjusted read brakes will pull the tractor/tow vehicle. The idea is to have the trailer slow proportionally to the tractor/tow vehicle.
Overtight trailer brakes will cause understeer and undertight brakes will cause oversteer. Both are not good for towing & especially dangerous in cornering situations.
The only time I've used the trailer brake lever is when the tractor got out of shape on ice. Pulled the lever, slowed down the trailer, which slowed the tractor & drug the tractor straight, let off the lever, pulled over, changed my underwear.
JasonSmith is offline
Old 01-21-2009 | 10:21 AM
Dock Holiday's Avatar
Charter Member #34
Eoh
Dock Holiday is offline
Old 01-21-2009 | 11:38 PM
Z06
EOH with Maxbrake.com controller.
Z06 is offline
Old 01-22-2009 | 03:28 AM
cig1988's Avatar
Ditto....nothing like watching the rear view mirror to see the trailer trying to pass the tractor. Oh yeah I've been in the underwear club as well.
cig1988 is offline
Old 01-23-2009 | 07:11 PM
Charter Member #34
+1
I forgot to mention the MaxBrake.
Man that thing is not pretty but it is the BEST. I tried a P3 and I was constantly adjusting it. With the Maxbrake just set it up once and just press the brake. The truck and trailer stop as one.
I would NEVER go back to surge brakes.
Old 01-25-2009 | 08:12 AM
excursion's Avatar
Just finished the conversion from drum surge, to EOH disc, yesterday and took the Black Thunder out for the first time, WOW!!!!!
That is the first time I feel confident in pulling the boat and stopping if need in emergency. After calibrating the controller, so easy, went out for a ride with the boat, was amazed at how easy it stopped.
Well worth the exspense, will not ever have anything else.
excursion is offline
mcraymond3
12
04-04-2008 09:40 PM
pullmytrigger
17
03-12-2007 09:50 AM
itilldo
6
02-05-2006 01:14 PM
pachangalpina
7
09-24-2004 09:00 PM
Magicfloat
04-16-2002 08:46 AM
