Question?
Old 01-25-2011 | 11:23 PM
Default Question?
What size truck would you recommend for towing a 36 Spectre cat on a triple axle trailer? A 1500 Dodge with a hemi wouldn't cut it, right?
Mastercraft240 is offline
Old 01-26-2011 | 12:01 AM
I think it would IF you
1) Upgrade the shocks and use a helper spring
2) Upgrade your front brakes at least
3) Go to a Class IV hitch
4) Do some engine mods-air filter, chip etc
5) The transmission is the weak link in that powertrain. Change to a stronger billet torque converter.
6. Change all fluids to synthetic if they're not already.
Catmando is offline
Old 01-26-2011 | 05:09 AM
Craney's Avatar
You can do all this and still not have enough truck,or you can buy a F350 and be done with it.
Craney is offline
Old 01-26-2011 | 06:30 AM
A boat of that size and weight requires a 3/4 ton minimum for safe towing. Don't kid yourself by thinking that strengthening the drive train and going to synthetic fluids will change things. The frame, axles etc. on a 1/2 ton just aren't strong enough and will flex under the stress of the load leading to poor handling loss of control. I trailered my Formula 271 (7,000 lbs. on trailer with gear) for years with 1/2 ton Suburban and while it did just fine I noticed a world of difference when I went to the 3/4 ton configuration.
08 fastech 292 is offline
Old 01-26-2011 | 01:03 PM
Nevermind the Hemi isn't strong down low, but a 1500 is not near up to the task of safely towing a 36ft Spectre... you'd be white knuckling it.
Quicksilver is offline
Old 01-27-2011 | 09:19 AM
Sydwayz's Avatar
Forum Regulator
No way. You want a dually anyhow towing a big cat.
Sydwayz is offline
