New Manning...
Looks great Mike. Looks like its a Torsion axle setup?? Be sure on your trip with the boat coming home, that your trailer is level. Torsion axles aren't forgiving in this area. What Im saying is, if the hitch is too low, it will put a lot of load on the front axle, and not as much on the rears. Too much and that can lead to tire blowouts. Vice versa if its too high.
Id definitely let some air out of the tires for running down to florida. 35psi should help it not be so bouncy. Now wetsand that baby and buff it out to a mirror shine!
PHP Code:
I've never heard of Timbren before, but did some research.
http://www.timbren.com/
Mike, did you install them in lieu of airbags?
Yep Brian. Just figured a little stability couldn't hurt. Don Cooper (formerly of the Fountain Ju-wanna Racing Team) owns an automotive service shop right down the block from my business, and he recommended them.
The axles are Axis torsions. And yeah Joe, it looks like a 2" drop is gonna do the trick, as opposed to the 6" drop I had on the Fountain. Might steal BZ's adjustable height hitch for the FL run just in case...
If needed, there are plenty of hitch/trailer places within a few miles of Pompano if you need anything. I've sourced balls and drawbars locally a few times for customers/friends.
Without any first hand experience, they look like they are contributing to your rough ride with the unloaded setup; especially if they are too tall. They look like they would transfer way too much axle movement directly to the frame for my comfort level. I can see valid use if you were running bigger tires and were worried that bottoming out would cause interference and damage; but that's about it. Good luck with the setup and please provide feedback.
