Texas Trailer Safety Inspection?
I was wondering if Texas requires an annual safety inspection? I found this link that talks about trailers over 4500lbs.
https://www.txdps.state.tx.us/rsd/vi...nCriteria.aspx
Our trailer is documented at 10,000 and if an inspection is required will any state inspection garage do it or will I have to go to a trailer shop?
Thanks in advance.
Thanks in advance.
Thanks for the reply, I will start looking for a shop.
They want the boat off the trailer!!!
What in any of the 15 inspection items require the boat to be off the trailer?
05.06 Inspect All Trailers, Semitrailers, Pole Trailers, or Mobile Homes Exceeding 4,500 Pounds Actual Gross Weight or Registered Weight For: (Listed in suggested order of inspection) Refer to Federal Motor Carrier Safety Regulations, if required.
* Check for evidence of Financial Responsibility on towing vehicle
1. Brakes (system) (If gross weight exceeds 4,500 pounds)
2. Tires
3. Wheel Assembly
4. Safety Guards or Flaps (if four tires or more on rearmost axle) Pole trailers exempt.
5. Tail Lamps (2)
6. Stop Lamps (2)
7. License Plate Lamp (1)
8. Rear Red Reflectors (2)
9. Turn Signal Lamps
10. Clearance Lamps
11. Side Marker Lamps
12. Side Reflectors
13. Side Marker Lamps and Reflectors (30 feet or more in overall length)
(Refer to Reference Section as per lighting diagrams and as applicable to the particular trailer being inspected.)
14. Serial or Vehicle Identification Number
15. Window Tint.
2. Tires
3. Wheel Assembly
5. Tail Lamps (2)
6. Stop Lamps (2)
10. Clearance Lamps
12. Side Reflectors
15. Window Tint.
2. Tires
3. Wheel Assembly
5. Tail Lamps (2)
6. Stop Lamps (2)
10. Clearance Lamps
12. Side Reflectors
15. Window Tint.
2. Tires
3. Wheel Assembly
5. Tail Lamps (2)
6. Stop Lamps (2)
10. Clearance Lamps
12. Side Reflectors
15. Window Tint.
