Towing w/ Gas?
That’s my plan for my 5.3 1/2 ton GMC.
Im only pulling approx 7k lbs but at 80, it likes gas, let alone in the mountains.
not may companies make a tank like that for gasoline, and I also believe you need some permits to transport over 50 gallons. Big difference in hazards carrying that much diesel vs gasoline
I’ve got a couple of extra poly, bellow deck gas tanks that I’m looking at for a temporary fix.
Smaller capacity like 15 - 18 gals.
My thought is an auxiliary pump in the bed w/a feed line to an adaptor in place of the filler cap and a switch on the dash.
When gas gauge gets low, Ill refill the tank w/o stopping.
We do a lot of trips from here in Ohio to Fla.
Where we normally go is 17 - 17 1/2 hrs straight through including 3 - 4 gas stops.
I do it non stop.
If I cut MPG in half pulling the boat, that’ll end my bonsai non stop trips due to added fuel stops.
I think this might work.
If we take a wk off, a trip to Fla is doable and worthwhile.
If we burn 2 days down and 2 back, it ain’t.
I do it non stop.
I towed my tiger all over the country with 8.1 lowered dually and allison trans.. 187k miles on it now and runs great, its the backup truck now as I have an 09 diesel, its nice to have it in case I need it, been thinking of maybe letting it go though.
I know plenty of friends that haul open and enclosed car haulers with gasser 3/4 ton trucks and have no issues. I actually searched for a clean gas truck before i settled on my duramax.
Here in the Pacific Northwest the 2500/3500 market is dominated by diesels. Then recently when I traveled to Florida I noticed lots of gas 2500/3500s, in fact I saw more gas than diesel. I was wondering why, then it hit me. Duh, Florida is flat, and gas is cheap. In the Pacific Northwest everything is a steep hill and gas is expensive!
I do it non stop.
I do it non stop.
YOur pump and filler cap idea sounds like an fire ball waiting to happen
Mine fills the tank via a Tee in the filler hose. Keeps the main tank always full thru gravity. There`s a shut off at the tank.
Someone asked me one time if my fuel gauge is broke cause it never moved from full in 7 hrs on the way to LOTO
