Need Opinions...... >
Need Opinions......
Need Opinions......
Old 05-05-2011 | 08:01 PM
  #41
And YES, the floor is due for a good scrubbing before the back seat goes in.
Originally Posted by low_psi
Well, finally I was able to get a few parts picked up from the upholstery shop. He is still not done............. But the work he has done is very nice.
The weather has sucked anyway so it isn't like the upholstry is holding me up. I will have the other side panel and back seat installed by tomorrow.
I added a second set of Kicker 6.5s to the Front of each panel and eliminated them from under the rear seat. Obviously, as can be seen in the
picture I have some wiring still to do. I looks worse than it is. Just have to connect the speaker wires and the LED wires.
low_psi is offline
Old 05-05-2011 | 11:14 PM
  #42
I know this is taking longer than you wanted but wow it's going to turn out great. I'm trying to come up with a plan to redo my interior and I like the idea of replacing the white with light gray; white is such a pita to keep clean and your combo looks sharp.
How bad were the side panels to remove? Do I need someone with long rubbery arms to help remove about 100 nuts & bolts?
Thanks,
Rick
Powerquest230 is offline
Old 05-05-2011 | 11:25 PM
  #43
After you get the seats out of the way and the lower panels, it is rather easy to remove and re-install the side panels.
low_psi is offline
Old 05-06-2011 | 05:31 AM
  #44
Registered User
Looks awesome. Nice colors, and will be easy to keep cleen Bob
EXCESS ENERGY is offline
Old 05-06-2011 | 07:05 PM
  #45
Here is a pic of panel 2, with LEDs. It was taken during day so the LED light is minimal but you get the point. Damn my Blackberry sux....
Tomorrow, wire speakers and CLEAN FLOOR!!!
low_psi is offline
Old 05-07-2011 | 06:02 PM
  #46
Ok, here are some better pics. Speakers installed and floor clean. Need to re-glue the seem @ the back, it has curled up as you can see in the pics. (it is concealed by the seat)..
Tomorrow the rear seat goes in! Then I wait for the powder coater and upholstry guy.......
low_psi is offline
Old 05-07-2011 | 10:13 PM
  #47
Looks great. Keep pics coming.
what ever is offline
Old 05-08-2011 | 02:46 PM
  #48
Back seat is in as well as lower panels. Lower panels were white, I sanded them and hit them with a "spray-bomb" Aluminum color then a clear coat. They have the perfect amount of gloss without being to glossy.
More pics to follow.
low_psi is offline
Old 05-08-2011 | 06:37 PM
  #49
Here are more pics, with the seat pedastals in. I am now at a stand still until I get more parts....
low_psi is offline
Old 05-08-2011 | 06:41 PM
  #50
I need to get it out in direct sunlight to warm it up a bit so I can beat the cushions in to shape and place....
low_psi is offline
