Used my Tantrum for the 1st time !
#121
thanks man . i got a great couple of friends helping out that know way more than i do about this stuff . GMCHEVYTECH on here is the main one helping . everyone needs to have a buddy like this guy anything he can do to help and he's on it . heck , the boat stays at his house in his garage .
#122
#123
Definition of the word boat... "A big hole in the water that you pour money into" or "Bring On Another Thousand" If it makes you feel any better I had to dump $3800 in to mine last year, Drive couplers, Shift Cables, plugs, impellers, Drive Oil, and labbed the props... only thing I had any choice on the the props. But you have a nice looking boat and once you get past the issues you will have a lot fun with it.
Hang in there!
Hang in there!
#124
Id say get the rest of the story before you talk. I put about 20 TROUBLE FREE hours on it last summer. The only thing I did to it was put new bowl gaskets in the carb when I bought the boat, change the all the filters and oil/drive lube, fix a leak around the fuel sending unit and put gas in it! I paid alot more for my new boat and have dumped over $2000 into it and had it out 3 times. Any suggestions Sir?
#125
Yes you can replace 1 piston. If the rest are good thats what i would do. Just hone all 8 cylinders as I said and don't worry about getting every last mark out. It should only take a thousandth or two. This is to straighten out the cylinders and ensure good ring seating during break in. And it needs to be done in a sunnen or compare able hone with a torque plate. New rings and reassemble. Its hard to see water leakage from the head gasket. Its just a drop at a time while its running and the steam from it melts the corner of the piston off til its thin enough to break. Any good machine shop can fix u up on a deck and hone job. All the blue engines since 05 use Cometic MLS head gaskets.
#126
#127
#128
#129
he is about the only friend i got willing to pay more than his fair share of the gas money . we also have to use his truck right now to go anywhere cuz i sold mine waiting on more $ to get a diesel
#130
My time will come im sure!
