Used my Tantrum for the 1st time ! >
Old 06-25-2013 | 09:42 PM
  #131
off to the machine shop she goes .... how much is this gonna run me ?
state1310 is offline
Old 06-27-2013 | 06:15 PM
  #132
rlj676's Avatar
Originally Posted by state1310
he is about the only friend i got willing to pay more than his fair share of the gas money . we also have to use his truck right now to go anywhere cuz i sold mine waiting on more $ to get a diesel
Originally Posted by GMChevytech
Haha your right! It is nice not having to worry about the expenses! But thats ok, im working on getting a money pit of my own soon! My time will come im sure!
Perfect haha.
rlj676 is offline
Old 06-28-2013 | 07:24 PM
  #133
so its kinda lookin to me like the cylinders will have to be bored . according to the part # on the pistons its already at a 4.5 bore . my question is , am I f**ked ?
Old 06-28-2013 | 07:36 PM
  #134
c_deezy's Avatar
4.5 should only be .030 over. You should be able to go to .060 no problem, if the block is good even bigger.
c_deezy is offline
Old 06-28-2013 | 08:36 PM
  #135
i sure do hope your right friend ! too many tiny numbers on the web confusing the s**t out of me .
Old 07-01-2013 | 06:52 PM
  #136
well guys , the block is f**ked and so am I .
Old 07-02-2013 | 05:43 AM
  #137
REMEDY's Avatar
4.470 is stock bore. JE Pistons or CP Pistons can make any size piston, so if its already 4.500 and it only needs a little cleanup you can get a 4.510 piston. Just check ring availability first. Both JE and CP can supply you with file fit rings for your bore size. The original pistons are made by JE for Merc. As I said in an earlier post, You can get away with a few minor marks in the cylinder if you just hone it. Marine engines typically have some water marks from water reversion. The power loss from not cleaning them all the way up is minimal if they arent too bad. If you have long deep scoring from a broken ring then it needs to be bored.
REMEDY is offline
Old 07-02-2013 | 06:55 AM
  #138
my engine guy said it cant be bored out anymore . unfortunately in this situation I trust everything he says .
Old 07-03-2013 | 05:01 AM
  #139
Originally Posted by ICDEDPPL
Damn dude I feel ya pain with everything going wrong on new purchase... I`m at $35, 000/hr cost to run my boat so far.. I`ve got 2 hrs on it... lol/cry
Man, I feel good about mine. 3rd year with it (can't believe this is the 3rd season since I bought the boat from you already) and within those 3 years, I've replaced the steering to full hydraulic(actuator, or whatever you want to call it went bad), all 3 trim cables (started wearing from age), fuel pump (priming arm had aged wear and tear), impeller pump (seals went from age and spit oil out everywhere), starter (ignition stuck, causing the gear to stay engaged so that was more of a fluke). Nothing that I can't say would be abnormal on a 15 year old boat. Now the thing is like new
state, keep your head up. Once you get her fixed, you'll be happy as he//
sleev-les is offline
Old 07-03-2013 | 09:08 AM
  #140
c_deezy's Avatar
Why can't it be salvaged? Was the bore gouged too bad?
c_deezy is offline
