Used my Tantrum for the 1st time ! >
Old 07-03-2013 | 06:33 PM
  #141
turns out the motor was bored .060 already . makes more sense now . still pretty bummed out . no one seems to have 502's 454's are everywhere .unless i want to spend 7k on a new one from 1800runsnew .
state1310 is offline
Old 07-03-2013 | 07:57 PM
  #142
c_deezy's Avatar
Food for thought:
http://www.offshoreonly.com/forums/g...ar-can-go.html
http://www.offshoreonly.com/forums/g...502-block.html
c_deezy is offline
Old 07-03-2013 | 08:28 PM
  #143
i have read both of those . im not sure i want to push it that far
Old 07-03-2013 | 08:38 PM
  #144
Sleeve it.
POWERPLAY J is offline
Old 07-04-2013 | 07:37 AM
  #145
Oh man that sucks, sorry to hear
ICDEDPPL is offline
Old 07-04-2013 | 07:49 AM
  #146
Jay, can't sleeve a 502. Siamese bore will distort the other cylinders unless you sleeve all 8.
Smokin gun has a 502 block that spun a main. Can be bought cheap and just needs to be align honed.
Unlimited jd is offline
Old 07-04-2013 | 05:52 PM
  #147
Whats everyone reading this opinion on boring .090 over ? Too risky ? Worth the risk ? Several companies build a piston for .090 .
Old 07-04-2013 | 10:08 PM
  #148
Have to sonic check the block. It's not uncommon to go to that bore but need to make sure there is no porosity in the casting or any corrosion issues
Old 07-04-2013 | 10:45 PM
  #149
c_deezy's Avatar
I would do the sonic test and see if it's even possible first. If the results are borderline, probably not. If the material is there to allow it, I would do it.
c_deezy is offline
Old 08-06-2013 | 09:42 PM
  #150
so after all the drama they were able to hone the cylinders .005 and get them cleaned up . valve job is complete , crank is turned , all gasket surfaces cleaned up , and new bearings . just waiting on the custom ordered diamond pistons to come in . really getting anxious to do some boating . start a new job in the next week or so and worried i wont have time for enough boating in the remainder of the summer .
