Used my Tantrum for the 1st time ! >
Old 04-22-2013 | 05:32 PM
  #31
Sorry for putting my two cents in.
I'll shut up and you can help him. Only trying to avoid a possible issue when I know right from wrong.
I need or want everyones two cents . could be anything . Tell me though , if the tanks is busted how big a pain in my a** is that gonna be to fix ?
state1310 is offline
Old 04-22-2013 | 05:49 PM
  #32
ActiveThunder's Avatar
You are ahead of yourself. You posted you saw a possible fuel stain earlier. Go with that. Run the thing on the hose and open your eyes.
Just remember 3 PSI means per square inch. That also means pump only 3 lbs of pressure in to the tank and see if it holds with something like a radiator pressure tester from AutoZone or where ever. NOT an air hose with a compressor.
If you really are unsure would you please get a surveyor or somebody with the experience to do it? Otherwise this thread will have a really bad ending, ok?
ActiveThunder is offline
Old 04-22-2013 | 05:51 PM
  #33
Originally Posted by lil red
Holy fack!!!! 20lbs!!!!! Damn that must be a good tank if it still holds any fuel! Did the deck bubble up in the middle??? Lol
Kinda like the lumbar support in my truck?
You get a short driver, simply pressurize the tank!
Old 04-22-2013 | 06:36 PM
  #34
OCDACTIVE's Avatar
A.T. Cult Member #4
thanks ! what ended up being your problem ?
Mine was a leak of the tank. Top of the starboard side crease. No way to have found it until they cut her out. She is all back together and testing this weekend.
Only when it was full did I realize. It also only leaked a tiny bit but that's all it takes to go "boom".
www.sbonh.org
OCDACTIVE is offline
Old 04-22-2013 | 06:42 PM
  #35
OCDACTIVE's Avatar
A.T. Cult Member #4
Listen to Pat... He really knows the steps to take before having to take the plunge!
www.sbonh.org
  #36
lets hope not ...
i hope not too!!! Fack!!
Drock78 is offline
Old 04-22-2013 | 06:55 PM
  #37
Like pat said, if you saw a stain and was dried up after shutting the engine off chances are its just a dried up hose or something. Fuel tank would continuously leak and the stain would be running back from the forward bulkhead.
Unlimited jd is offline
Old 04-22-2013 | 07:19 PM
  #38
We are gonna check everything around the stain in the next couple of days . GMCHEVYTECH lifted it up in his shop earlier and had it tilted back . no gas ran out , so probably not the tank .
I appreciate everyone's comments and suggestions , and Im sure they will help us find the problem .
Old 04-23-2013 | 07:26 AM
  #39
OCDACTIVE's Avatar
A.T. Cult Member #4
If it were the tank you would know it by now. (As long as the tank is topped off)?!?!?!
You would know by the smell in a heartbeat.
www.sbonh.org
Old 04-23-2013 | 07:56 AM
  #40
check the seal around the fuel sender....
Drock,,to give you a idea about how much 20lb of pressure is,,,the radiator cap on your car can only handle 12-15 lbs of pressure...
boatnt is online now
