imco shortie >
imco shortie
imco shortie
Old 01-31-2005 | 07:14 PM
  #41
baja36ft's Avatar
Default Re: imco shortie
No not really just thinking out loud!!!!!!!!!!!!
baja36ft is offline
Old 02-08-2005 | 08:02 PM
  #42
liquid asset's Avatar
30" labs were best when we tried this on a 33, but hard to get on plane, 5 blades would be a lot better Im sure
liquid asset is offline
Old 03-17-2005 | 06:29 PM
  #43
Have we done anymore "playing"
with it ?( 5 blades) ????
Inquiring minds want to know
JaayTeee is offline
Old 03-17-2005 | 08:25 PM
  #44
crayolacrazy's Avatar
Iwas told one way to test, if you can go higher is trim up a little if you can get on plane it should accept shortys.I here people saying there making power not getting speed check the haul for hooks Baja know for high slip factor Im running 02 33 660 hp.first year 87 is all I could get .Straight edged last 8 feet and installed imcos ,spinning same props 32 labs same rpms 4% more efficnt 95 -96 My prop shaft is three and threequarters from bottom of boat slip factor is 13%
crayolacrazy is offline
Old 03-19-2005 | 03:23 AM
  #45
garshev's Avatar
CRAYOLACRAZY, How does your 33 ride and handle at those high speeds?? Just curious what would happen if i whippled my 500's.
garshev is offline
Old 03-19-2005 | 06:27 AM
  #46
baja36ft's Avatar
Sorry nothing new yet i took the motors out and did alittle
work.they are going back in next week. the drives are 41/4 below the hull there is no hook in the bottom when i took it
out i tried to trim up and down tab it but it was real hard to get on plane but i did with 26 bravo's they were to small
at the rev limit.so julie is sending me a set of 5 blades the
first week in april i also have a set of bravo 30's i will try
i will post the results!!!!!!!!!!!
baja36ft is offline
Old 03-19-2005 | 06:44 AM
  #47
Dock Holiday's Avatar
Charter Member #34
Thanks for the update.
Best of luck, I hope it all works out well.
Keep us posted!
Dock Holiday is offline
Old 03-19-2005 | 07:09 AM
  #48
baja36ft's Avatar
I sure will how is you'r project going?? any results?
baja36ft is offline
Old 03-19-2005 | 11:03 AM
  #49
Charter Member #34
The wife and I had the pleasure of riding on Bobby's 33 in Jacksonville last year and I can tell you first hand that is handles the same at 90+ as it does at 70 MPH.
I have also ridden in a 2001 36 Outlaw with Whippled 502/509's and it was hitting 92 on the GPS.
The 33, 36 and 40 Outlaws all handle very well at all speeds. It just takes a lot of power to get them up there!
Attached Thumbnails imco shortie-lake-cumberland-pr-2004-141.jpg   imco shortie-lake-cumberland-pr-2004-142.jpg   imco shortie-lake-cumberland-pr-2004-143.jpg
Old 03-19-2005 | 07:00 PM
  #50
baja36ft's Avatar
That Is Very Nice!! Lets See A Pic Of You'r Motors????
baja36ft is offline
