Go Back  Offshoreonly.com > Owners Forum > Checkmate
Checkmate speeds >
Checkmate speeds
Checkmate speeds
Old 09-11-2008 | 11:48 AM
  #31
noyzee's Avatar
Originally Posted by GOFASTJUNKIE
I know what you are saying. I did see 71 now I can't get it that fast. I do have the 385. I figure after the plugs are changed and I put high test back in it, I should see 71 again. Where I boat now only has regular gas. They do not even offer a "plus" gas. If mine was off as much as yours is, then I would think something is wrong. What rpms can you get to?
Enforcer, what you said in your post, is what has been explained to me before. Somebody told me it was running "downhill"????? or something like that.
i run it right out to 4800-5k on the stock tach.
seems like somthing is wrong if your 10 kore house and that much faster.
whats your boat weigh?
noyzee is offline
Old 09-11-2008 | 01:40 PM
  #32
I think I weigh around 4500???. The weight has to be close to what your weighs. Did you read the post by Enforcer? It makes sense as to why I have not seen the 71 again. It does sound like somethig is wrong on your end, if you are running it out to 4800-5000. I can't believe the manifolds that I installed could make that much difference. I will need to check what size prop I am running. I have will not be able to find that out until next week. The boat is still in PA at the lake. Maybe the 10 extra horse power makes that much difference.........
GOFASTJUNKIE is offline
Old 09-11-2008 | 02:41 PM
  #33
noyzee's Avatar
i know im told that the 496 has some restrictor in the manifold thats good for maybe 1 mph, and it comes with the nice elbow style in place of the old 454 flat style, but i dont know.
its strange. id like to get a weight of the boat and see, the boat spends all summer in the water, i wonder if it soaked some water into the hull and is now 5000 pounds or somthing?
noyzee is offline
Old 09-12-2008 | 12:46 PM
  #34
Smile
I saw your post in the genral forum. Yes, i am running a 3 blade. I am fairly sure it is a 23. I am trying to find the one prop I have laying in the garage. It is is the 23 then I have the 25 on the boat. But with the speeds I have been able to get, i am fairly sure it is a 23 3 blade mirage. I don't know if that helps you any. I am actually thinking of putting a 4 blade on for next season but all of this talk is having me doubt that........
Old 09-12-2008 | 12:54 PM
  #35
socalstone's Avatar
I know a guy with a 97 or 98 25' Checkmate - Convincor.
Stock carbed HP500 and standard bravo. He said it ran 80 on gps.
This thread has me scratching my head.
Was he bsing me? How much does a 25 Checkmate weigh and how fast does it truly run with an HP500?
socalstone is offline
Old 09-12-2008 | 02:26 PM
  #36
He should be right around 70mph, to get 80mph its more like 650hp....
Find out what pitch, drive ratio and rpm he's running and that will tell you..
sabo is offline
Old 09-12-2008 | 04:29 PM
  #37
B S
Magic Medicine is offline
Old 09-12-2008 | 04:33 PM
  #38
Vinny P's Avatar
I hate the winter!!
Absolute BS!! It took me 720 hp to get to 85 mph. Even then, condition and load have to be perfect to get 85, more likely, 83 is achievable.
Vinny P is offline
Old 09-12-2008 | 08:26 PM
  #39
socalstone's Avatar
LOL. Guess I was a sucker. thanks for the info.
If I'm ever out on his boat again, I'll bring my gps and set the record straight. Great boat though.
Old 09-13-2008 | 07:14 AM
  #40
RJBBC's Avatar
Registered User
Originally Posted by RJBBC
2000 259 Convincor 72mph GPS with low fuel and 1 person on boat (454MAG 461HP 26 Bblades labbed prop). I am looking forward to seeing what this boat will run w/ 600HP. Hopefully we will find out in 2009!
72mph in ideal conditions. If another person is in the boat, water is flat, air temp above 85, etc the boat is running in the upper 60s. I agree with Vinny and some others 80mph with a carbed HP 500 is on the optimistic side.
RJBBC is offline
