Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Tell me the differance  between Marine Engine and Auto engine...... >
Old 04-16-2007 | 10:28 AM
psmith's Avatar
psmith
Default Tell me the differance between Marine Engine and Auto engine......
What is the differance in a marine engine and an auto engine.
psmith is offline
Old 04-16-2007 | 01:55 PM
Maybe try in the general question and answer section........
cigarette28ss is offline
Old 04-16-2007 | 02:03 PM
Wally's Avatar
Were doomed!
In general its gonna be a slightlty different cam centerline to avoid reversion.....Coast guard approved acc to keep from generating sparks (alt, start, dist).... Stainless or brass hardware like nuts bolts freeze plugs to help with corrosion...maybe a few different gaskets depending on type of use (i.e Head gaskets) and possibly slightly bigger tolerances for piston bore and oil clearences. Now its not to say that you cant get a stock auto engine to work..its just a question of keeping it alive the longest since you have to remember....auto engines are used to only seeing life between 1500 and 2500 rpm running around everyday...our marine engines run at 2500-5000rpm+ constantly
-Wally
Wally is offline
Old 04-17-2007 | 05:17 AM
psmith's Avatar
psmith
Thanks, the high RPM's will be the main bang....
psmith is offline
gettin wet
Do It Yourself, Boating on a Budget
3
06-20-2008 08:22 PM
techman
03-12-2008 12:17 PM
joee
1
05-08-2006 08:51 AM
99fever27
9
04-18-2006 05:37 AM
kingrich
8
05-18-2005 07:11 AM
