79 mistressm fuel system questions, help >
Old 06-21-2005 | 04:50 PM
ratman's Avatar
Default 79 mistressm fuel system questions, help
i want to upgrade fuel supply lines from the tanks back on my 35 ft mistress. i am wondering how to access the fuel tanks as i want to run 1/3 id fuel lines from the tanks back including new pickup in the tanks. what does the fuel system valve near the floor do? where is the fron tank located? how do i access the tank to install new pick up? how do i rear tank to replace the fuel pick up thx for any info you can share.
ratman is offline
Old 06-21-2005 | 04:52 PM
ratman's Avatar
Default Re: 79 mistressm fuel system questions, help
oops, thats 1/2 id fuel lines...
ratman is offline
Old 06-23-2005 | 03:05 PM
Stalkin's Avatar
Are We There Yet?
Hey Rat, I had a '78 Mistress and did the same thing. Mine had a hole under the rear seat where the sender was and then another hole behind the bulkhead and forward of the engines. The second hole was where the valves were to control which tank the engines where running off of. I relocated the valves and connected to the tanks at the point. I wish I had some pictures of it for you, but I don't. Hope this helps.
James
Stalkin is offline
Old 07-23-2005 | 07:30 PM
ratman's Avatar
thx james... mine has the hole under the back seat but none in eng comp. the tank selector valves were alreay mounted by the helm, and the access to front tank was under the aft end of the v birth. everything came out sweet. will post pics of verything when she's 100%, ratman
ratman is offline
cliff3466
2
04-22-2008 11:27 AM
Formula311-SR1
4
09-06-2006 09:52 AM
Rage
13
01-14-2006 05:53 AM
Pure Energy
2
06-18-2003 07:53 AM
blue64drop
22
10-02-2002 03:14 PM
