head problem, haha >
head problem, haha
head problem, haha
Old 09-08-2006 | 04:51 PM
grimmy's Avatar
Default Re: head problem, haha
anyone else?
grimmy is offline
Old 09-09-2006 | 06:29 AM
cig1988's Avatar
Get a buddy to help you do this. Have him/her in the head to operate the switches. Go to the macerator with test light. You can get a good ground source if you remove the panel in the head behind the dash. There's a grouund block in there. With a long piece of wire (ground) and test light by the macerator have someone operate the lower switch (macerator) and check for power.
To check the pump remove the storage compartment to the right of the sink. Actually I would start here 1st. Check to see if you have power into both switches. USE THE GROUND BLOCK W/YOUR TEST LIGHT behind that panel. I'll bet it's the power source going to those switches. Test your fuses with the test light on each side. They are located under the steering wheel access.
Good luck
cig1988 is offline
jmeng
05-30-2007 04:52 AM
Steel Outlawed
7
03-08-2007 07:05 AM
MILD THUNDER
1
05-14-2006 10:16 PM
GG33ZX
6
05-04-2004 07:15 AM
timucin
25
12-05-2003 12:00 AM
