Electrical problem >
Electrical problem
Electrical problem
Old 08-27-2008 | 07:48 PM
gripit's Avatar
Electrical problem
I was trying to hook up a fresh water pump rocker switch behind my 88 bullet dashboard. I must have hooked up something wrong because when I tested my blower rocker switch I noticed a power surge on the dashboard evidenced by multiple gauges moving. Then their was a popping noise. The result was that multiple systems do not work via the battery but work with shore power hooked up. For example, the hatch is wired to work with the battery switches selected to off. Now the hatch will not open and I hear clicking noise from a solenoid switch mounted on the bulkhead in the engine compartment. In sum, systems will work with shore power but not with batteries. Any suggestions?
gripit is offline
Old 08-28-2008 | 06:16 PM
gripit's Avatar
Fixed by itself.
gripit is offline
Old 08-28-2008 | 09:30 PM
hurleyr's Avatar
Hurley
Ground to hot??
hurleyr is offline
Old 08-29-2008 | 09:59 AM
gripit's Avatar
How does a ground to hot work or not work in a 12 volt system?
gripit is offline
Old 08-29-2008 | 11:41 AM
hurleyr's Avatar
Hurley
I'm no electrician but my buddy had a problem on a Vette one time where he accidentally hooked a ground wire to 12V hot and it caused all kinds of problems. It was activating windshield wipers, radio, and other equipment. It took a while to find it becuase it was back feeding so many other areas.
I was just curious what the problem was. Electrical problems can be tricky. Sometimes its just a simple fix like this one was. His turned out to be a ground wire hooked directly to the starter positive terminal. Heck the wire fit the terminal.
hurleyr is offline
carney
Baja
11
05-06-2008 01:40 PM
wheatieworld
2
09-30-2006 07:13 AM
riski bidness
1
08-11-2006 06:58 PM
kennyo
3
05-04-2006 01:33 PM
RJ1340
1
05-02-2004 10:17 PM
