restoring 20' cig.... NEED ur Thoughts!!! need info!!! >
Old 03-22-2010 | 07:05 AM
  #91
A friend of mine installed a 500hp big block motor in his a couple of years ago it runs around 80mph every day its a real good combo .He has a old set up mec trans and TRS outdrive deep in the water
Mike Baldwin is offline
Old 03-22-2010 | 10:52 AM
  #92
there was room for the BB and TRS trans ?
tomuchstuff is offline
Old 03-22-2010 | 10:55 AM
  #93
black hawk is a bravo style, not sure what you mean by velt?
the speedmaster TRS drive uses a c72 velvet drive tranny. so was wondering if blackhawk also needed a tranny...
Old 03-22-2010 | 11:26 AM
  #94
I would think if you where starting out from ground zero it just makes it so much easyer to use modern day parts a blackhawk or a xr drive and forget that trans less moveing parts is always a good thing . I had a old set up for a few years and now have xr drive it is so much better
Old 03-22-2010 | 12:50 PM
  #95
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
I am putting a ITS and a Blackhawk on mine The ITS has an advantage of integrated hydraulic steering.
With the speed you are working you will be done before I start on mine. I have the ITS, Blackhawk 500 HP Motor and a bunch of parts but have not touched hull yet that will start to change this weekend as the weather is getting nicer and I have to work outside.
Great job so far on yours
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-22-2010 | 01:21 PM
  #96
offshoredrillin's Avatar
no sir it does not need one. i have to agree with the above posts, stay with a more modern setup, the money spent now will pay off down the road.
offshoredrillin is offline
Old 03-22-2010 | 07:14 PM
  #97
seems as if the blackhawk is the drive to run,,,, I will have to look into the ITS set up..... any one running a bravo max machine drive ? seems like guys are running big 14x22 inch tabs around 550hp....
Old 03-22-2010 | 11:28 PM
  #98
well the boat yard gets about 20 a day so need to finish her to the point i can get her into my shop ASAP...... the day i set the deck cap she will move.... i need to build a motor for her takes a little time... going to need to be a dart block stroked for this one... thinking 540ci roller iron heads not crazy lift give me around 650hp at 5k and will last a good amount of time.... i have a line on a blackhawk will move on it first.... i run a capliano helm on my bert may run one with the cig dont know if its 1 /2 line can hook to an its gimble ......
Old 03-23-2010 | 07:42 AM
  #99
I think now your talken that 540 motor will give you a lot of bang for your buck i have one in my 20 and it has done a graet job . But if you have a little extra money i would go with aluminun heads to save the wieght
Old 03-23-2010 | 07:52 AM
  #100
Airpacker's Avatar
I happen to know where there is a fresh black hawk drive with 31's for sale
Airpacker is offline
